Too Much Retard cause Misfire?
Old May 10, 2010 | 07:57 AM
Sp3no's Avatar
Sp3no
Default Too Much Retard cause Misfire?
I tweeked my cam timing to a little over 6 degress retarded on the exhaust cam at the weekend, i turned the car over numerous times by hand, there was not contact between pistons and valves. At first i thought it was fine but i started it again last night and there seems to be a very minor miss fire, have i bent a valve or can the retarded timing cause this. It revs fine, its idle is just a little unstable. I have just fitted underdrive pulleys could it be these?
Old May 10, 2010 | 08:00 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Yes it could be the retarded cam timing affecting it, as it will need a tweak to the map now as the cylinder fill at idle will almost certainly be less than it was, so if it was a touch on the rich side anyway it could now be just that bit richer again by enough to make the idle wander a touch.
Old May 10, 2010 | 10:17 AM
Sp3no's Avatar
Sp3no
Thank you very much Chip, my mind is now at rest, the map that is on there is for 97Ron fuel and it currently has 95 in it, the plugs are very sooty. I will switch the map to my 95 one and see if it improves.
Thanks Again
Old May 10, 2010 | 10:42 AM
rog's Avatar
rog
I never let retards near my car.....
Old May 10, 2010 | 10:44 AM
Chip's Avatar
Chip
Thanks Again
It probably needs a new map to suit the new cam timing, not just a different octane map.
Old May 10, 2010 | 11:35 AM
Sp3no's Avatar
Sp3no
I can see this getting expensive lol
I did chuckle to myself when i typed out the thread title!! Problem is im the retard
j.hammond1
30
Oct 31, 2021 05:28 PM
Fiddy
21
Sep 29, 2015 06:10 PM
Brickhouse
Sep 21, 2015 11:00 AM
Marino
Sep 12, 2015 11:10 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
