Seen a set of old style comps, there et42 though? will these be ok as dont want them to sit in the arches.Also there 7j? what width/offset is correct/best to go for? Thanks
as above just about to put my comps on and mine are et35 7j on 16's and i'm going to be running 215's on the front for grip and 195's on the rear so can get as much clearence for my coilovers and outer arch lip, you could buy the ones you've seen and put a 5mm spacer on it
There 15s the ones ive seen as wanted to try smaller rims as not happy with the way the car handles on 17s.so if there et42 with a 5mm spacer this will bring it down to et37 or 10mm down to et32 wont it.
I think 300mm will be very tight on 15's, i know your after purpose rather than looks but i think 16's is a good compromise...15's will look pretty damn small.
ive been trying to put standard s1 wheels back on my car but ive got 300mm hispec discs and 2wd cosworth 4pots so i need a spacer ect to clear the front of the caliper can anyone tell me what i need ..... only needs moving slightly
I've got 17x8 ET35's on mine with 205/17/40 tyres. If I were to buy the wheels again I would go for 7's or 7.5's as the 8's are too wide really, but they were brand new and boxed for £450 IIRC so didn't have much choice.
your soft line should only be 7j wide unless they were diamond cut ones as they were 7.5j and i've put mine on today and they fit so much better and they are comp mo's 7j16 et35 and gives more space everywhere even with the 215/40's on the front
Think im gonna wait till i find a set of 7x16" then mate. Got any pics of yours with the new wheels on? and your right, my mistake they are 7" wide the current wheels
pics?? ive had soft line and diamond cuts and they both very close,stunning wheels tho.
