Mk 3 Escort........with a YB engine (yes another)!
Old May 8, 2010 | 08:52 PM
DazC's Avatar
DazC
Default Mk 3 Escort........with a YB engine (yes another)!
Yes!
Me and AJC have a small collection of Mk 3 Escorts and decided that we should combine a Series 1 with the drive train (or most of) of a rear drive Sierra!
Here is the shell we decided to convert.
And the transmission tunnel
tunnel
We had to make some engine mounts to fit the engine onto.
Then we had to make some mounting arms to support the engine.
Then once we had the engine mounted, we had to look at the gear box. It turned out that the Mk 1 and 2 Escort tunnel wouldn't be sufficient and that we'd have to get another made, or risk it looking like a patch work quilt.
Currently this is how the shell sits. We need to get the tunnel made and welded in. Then we can look at mounting the gearbox. Once that is done, it's onto the rear end.
Old May 8, 2010 | 08:58 PM
graham c's Avatar
graham c
looking good daz dont stop now
Old May 8, 2010 | 08:59 PM
jamieclements's Avatar
jamieclements
keep the pics & updates coming . this looks like a great project mate
Old May 8, 2010 | 09:04 PM
jonny s2's Avatar
jonny s2
there will be more mk3/4 escorts running cosworth lumps than sierras by this rate, keep the updates coming
Old May 8, 2010 | 09:10 PM
DazC's Avatar
DazC
We was going to build 2! I'm duplicating everything I have made so this can be replicated on another shell!
Old May 8, 2010 | 09:14 PM
whizzisat114's Avatar
whizzisat114
lookin good , love the engine mounts they look proper motorsport
Ill be watching this thread
Old May 8, 2010 | 09:56 PM
ASHCOSSIE's Avatar
ASHCOSSIE
y doesnt every one build them like this instead of putting in the whole floor ?????
Old May 8, 2010 | 10:03 PM
auto-diag-tech's Avatar
auto-diag-tech
nice work, good to see something a little bit different from the norm on this type of conversion!
Old May 8, 2010 | 10:20 PM
katluke's Avatar
katluke
Are you going to fit the Sierra rear beam or an atlas ?
Old May 8, 2010 | 10:24 PM
Less.'s Avatar
Less.
having a mid life crisis
well daz if it anything like the standard of AJC,s and your S1 restoration it will be a cracker
Old May 8, 2010 | 10:30 PM
Pete frst's Avatar
Pete frst
keep them pics coming,christ its better documented than my Haynes manuel.....
Old May 8, 2010 | 10:39 PM
JayCC's Avatar
JayCC
Love these! Hope you can find a way to keep the front grill in though^^ Noticed a lot of the converted mk3's lose the front grill (Either that, or I'm not looking hard enough!)
Old May 9, 2010 | 01:24 AM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
suppose its all down to choice really , i went the full floor bulkhead route as it gives more of a finished factory look to it rather than the just enough to do the job look ,
thats not a dig daz mate,
also ,simplicity re engine mounts , arb , and gear box mounts, its all there already allinged ,
aye you bracing the floor to the new tunnel section ??
what route you going re the steering rack bud ??
good build , will keep an eye on it
beef
Old May 9, 2010 | 06:18 AM
Brian's Avatar
Brian
Excellent project
Brian
Old May 9, 2010 | 11:42 AM
will keep an eye on this
Old May 9, 2010 | 11:57 AM
H7 CYA's Avatar
H7 CYA
Cool project looks like you've made some good progress!
Old May 9, 2010 | 12:07 PM
Miller 3's Avatar
Miller 3
Those engine mounts look mint
Old May 9, 2010 | 02:03 PM
katluke's Avatar
katluke
Just cuious now,which way did ford do it on the RS1700T ? Did they fit a floor etc like Beefys project or did they do it like DazC is doing here?Both cracking projects by the way. http://www.rsownersclub.co.uk/car_info/esc31700t.htm
Old May 9, 2010 | 04:31 PM
DazC's Avatar
DazC
Thanks Less.
It should retain all it's Series 1 looks including the front grill.
beef
Not taking it as a dig Beef. It's all down to personal preference and I wanted to do it this way to keep the rest of the shell as factory. Plus I couldn't be arsed to cut a floor out and make it all fit!! Although I can see why it's done that way as once it's in, everything bolts up.
The tunnel will be made of 3mm steel and braced to the chassis that I've cut out of the bottom of the bulkhead. I'll be adding stength where I can and plan to brace the tunnel at the rear to the chassis legs. I plan on making a WRC type set up for the rear once I've decided what diff to use.
Rack wise, I'm going to use a spare 2wd rack AJC has lying around in the workshop and make a crossmember to support it once I have a matching 2wd column and pedal box. I'll need them all so I can get measurements.
They had a gearbox in the rear on the RS17T and some fancy independant set up similar to the WRC Escorts from what I can remember. See my reply to Beefy above for the rear end plans.
Old May 9, 2010 | 04:37 PM
series1john's Avatar
series1john
Looking good that lads will keep a close eye on this build, I notice my brothers old 16 i is still hanging around BLJ 619Y
Old May 9, 2010 | 04:44 PM
DazC's Avatar
DazC
That belongs to my apprentice now. It's being slowly built up an and when he gets money to spend on it.
Old May 9, 2010 | 09:07 PM
katluke's Avatar
katluke
Thanks for the reply Daz,will be watching the updates as they come in
Old May 10, 2010 | 07:05 AM
boothy's Avatar
boothy
Good work daz and andy saw this when i was up
Old May 22, 2010 | 06:44 AM
AJC's Avatar
AJC
I think daz stitched new tunnel in last night
Old May 22, 2010 | 08:12 AM
graham c's Avatar
graham c
should be on its wheels now come on daz
Old May 22, 2010 | 12:15 PM
smitsturbo's Avatar
smitsturbo
nice
Old May 22, 2010 | 12:27 PM
Darylc.'s Avatar
Darylc.
49cc superbike!
I'd love to do this, keep us updated
Old May 22, 2010 | 12:49 PM
fiestamad's Avatar
fiestamad
this is nice carnt wait to see it finished
whens the next update
Old May 22, 2010 | 02:33 PM
Looks like plenty of fabrication to do to this.Looking forward to rwading the updates.
Old May 22, 2010 | 03:48 PM
andy escos's Avatar
andy escos
you do not need to make the trans tunnel out of 3mm steel its way to heavy 1.2 or 1.5mm is more than enough .done some nice work on the engine mounts though .
Old May 23, 2010 | 09:04 AM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
coming along well
Old May 23, 2010 | 02:12 PM
DazC's Avatar
DazC
I think it's been made out of either 1.8mm or 2mm. It was copied from a wide tunnel for the Mk1 and 2 Escorts but with a template shaped to the contours of the Mk 3 floor. Unfortunately it was slightly short at the top of the tunnel so I will have to get an infill piece made to join the top into the bulkhead but it's nothing major. I still need to trim some of the floor pan along the edges of the new tunnel underneath but internally it's fully welded in now.
I'll get pictures when I've made some more progress. I've been pretty busy at work so haven't had the time to nip out and get things sorted. I will be running out of things to do up to the point were I decide what diff and rear hubs to use.
Old May 24, 2010 | 07:59 PM
rizla's Avatar
rizla
Ill be keeping an eye on this keep up the good work
Old May 29, 2010 | 07:32 PM
AJC's Avatar
AJC
On it's spit getting welded.
Old May 29, 2010 | 07:34 PM
graham c's Avatar
graham c
bloody hell daz c caught doing some think. that,s a first !
Old May 29, 2010 | 09:04 PM
Gav Diamond's Avatar
Gav Diamond
Looking good Daz, keep up the good work and updates
Old May 29, 2010 | 09:18 PM
Darylc.'s Avatar
Darylc.
49cc superbike!
can't wait to see it finished, keep the updates coming
Old May 29, 2010 | 10:28 PM
james kiely's Avatar
james kiely
great project daz
Old May 30, 2010 | 01:18 PM
DazC's Avatar
DazC
It's been seam welded on the front end externally (unerneath, bonnet area, inner wings/wheelarch are) and the tunnel has been 90% welded in. As the tunnel was made from a Mk 1/2 tunnel it's not quite right. I need to make an infill piece at the top to bridge a gap to the bulkhead.
I'm going to look into starting on the back end next. The reason being that I need to get a donor car to remove a pedal box/gearbox and I need to trial fit some seats. I may need to narrow the tunnel near the pedals and also near the seats so that they fit (gearbox to make sure I don't narrow it too much. Seats and pedal box to trial fit to see how much I need to narrow it by). I'd sooner buy a donor than all the little bits as it's just easier as everything is there that you need.
Old May 30, 2010 | 01:30 PM
DazC's Avatar
DazC
When said we have a collection of Mk 3 Escorts lying around.....
Seam welded underneath
Tunnel in
On the spit
