saph problems
Old May 8, 2010 | 05:18 PM
johnandhissaffy's Avatar
johnandhissaffy
white fords look best
Default saph problems
hi need some help iv just brough some 4 pot cosworth frount brakes ,pads and disks for my saph what else will i need to make the most out of them at the moment i have 1.6 pinto master cylinder and sevo what one do i need to get next ??
and what rear axle is best for me to look out for ?
and i have been having a problem with my starter motor i think its down to touqe of the engine as iv done a convertion and i have now got a 2liter twincam bolted to a t9 box and i think the starter motor is getting distroyed by the engine is this a thing that it could be
happening
my car was left standing for about 3 days and i went to go and start it but nothing didnt even want to turn so my mate put a power charger on the battiery and it span but very slowly and i tryed bumping it nothing we rejoined the earths still nothing can someone help me out please
cheers
johnandhissaffy
Old May 8, 2010 | 07:59 PM
You don't need to rear disc it, can use the xr4i rear drums, much much larger than the std ones, when I fitted 4 pots to my 2.1 sierra/auto I kept the std 2L master cyl and had no issues at all with extended travel, but did put braided lines on at same time, I alos enlarged the bore of the connection on the inlet for the servo hose by 2mm for a slightly grippier pedal.
As for the starter issue fully charge the battery first, was the s/motor not origninally off a 2L twinky then ?
Old May 9, 2010 | 01:35 AM
johnandhissaffy
yh was off an twincam before my car will only last 2 days max without going flat 3 or 4 days and I need a starter motor its bollox proper head fuck and iv tested the battiery and aulternater and its showing around 13.8 mark upwords
Rammer46
Sep 18, 2015 08:31 AM
landaqmabba
Sep 15, 2015 07:16 PM
Flateric_2002
Sep 15, 2015 08:41 AM
dojj
28
Sep 11, 2015 10:00 PM
