Won't idle
Old May 6, 2010 | 08:18 PM
mr_joe0606's Avatar
mr_joe0606
Default Won't idle
Hi guys went for a drive tonyt and broke down :-(. Was all fine untill I was pulling up to a set of traffic lights on a bypass and when dropping down the gears it's was popping and banging loud nevered here'd it like this different to normall if you no what I mean. And when pulled up to stop the revs died and now it won't start. On the way home on toe with my dad I put it in gear and it starts on the bump but holds no idle!!
Any help please !!!
Cheers joe
Old May 6, 2010 | 08:26 PM
studabear's Avatar
studabear
have you blown a boost hose off or air leak somewhere?
Old May 6, 2010 | 08:33 PM
mr_joe0606's Avatar
mr_joe0606
It's in ma garage but I don't think so will be haveing a propa look on Saturday am so pissed of !!!
Old May 6, 2010 | 08:45 PM
Rob_DOHC's Avatar
Rob_DOHC
Massive air leak (probably), the popping and banging is typical of lean mixture, check all hoses round the back of the inlet manifold carefully etc.
Old May 6, 2010 | 08:58 PM
mr_joe0606's Avatar
mr_joe0606
Cheers guys hope it is this joe
Old May 6, 2010 | 09:57 PM
studabear's Avatar
studabear
my s1 (back in the day) was a fooker for blowing the hose of the turbo to the bottom of the intercooler, a set of samco's cured it
Old May 8, 2010 | 11:25 AM
mr_joe0606's Avatar
mr_joe0606
Cheers guy it's sorted was a little vacum pipe to the metering unit.
Cheers for the pointers joe
fordrallycar
Sep 30, 2015 07:57 PM
dojj
Sep 29, 2015 10:32 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
