Brake discs & pads upgrade or not ?
Old May 5, 2010 | 08:14 PM
m7ck's Avatar
m7ck
Default Brake discs & pads upgrade or not ?
hi chaps
time for some new discs & pads all around
car is 2wd saff 340bhp just road use
should i just have std's again or :
grooved
drilled
drilled & grooved
which pads
any info appreciated thanks
Old May 5, 2010 | 09:23 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
330s with 4 pots mate aps if u can when i had 350 the standard size brakes were shit
Old May 5, 2010 | 11:18 PM
Char1ie's Avatar
Char1ie
Originally Posted by m7ck
hi chaps
grooved
drilled
drilled & grooved
which pads
Grooved discs, DS2500 Ferodo pads.
Charlie
Old May 6, 2010 | 05:24 AM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
ebc grooved and drilled and yellow stuff pads. there very good and they get abused a little and there is no sign of wear, been on my car for 3 years, if your not wanting to go down the bigger calliper route
Old May 6, 2010 | 05:31 AM
Papillon's Avatar
Papillon
im using tarox pads and std size grooved discs, very satisfied. think the std 2wd works very well, i might change to bigger in the future but mostly because it looks cool
Old May 6, 2010 | 05:52 AM
dojj's Avatar
dojj
Resident Wrestling Legend
and a set of 17's to go with them
you won't regret it
Old May 6, 2010 | 07:11 AM
ajamesc's Avatar
ajamesc
we must drive differently lol because mine wouldent stop for shit and faded out big time with standards running 350!
Old May 6, 2010 | 08:27 AM
Papillon's Avatar
Papillon
mine has never faded and the pedal is stiff like a young mans c*** i do have racing fluid and steelbraided lines aswell. had it on trackdays and done some 120mph+ heavy braking without loosing confidence. as long as the bits are fresh they work great IMO. ofcourse, bigger brakes wont make it worse though
Nov 1, 2015 06:53 PM
locum8
Oct 1, 2015 01:50 PM
Sp3no
Sep 27, 2015 07:23 PM
