Please remove this thread. Nothing is for sale now due to idiots!!!!!!!!!!
3 door resto in progress
200 block long studded
mahle low comp with valve cut outs
4x4 crank
4x4 rods
wrc shells
burton high pressure oil pump
coopers ring head gasket
2wd sump
£1500
2wd head with new:
valves
isky valve springs
INA followers
bd15 inlet
ported and polished (ported 26mm inlet 25mm exhaust)
standard exhaust cam
piper vernier pulley
£800
l8 ecu with MSD 83lb chip
£300
siemens 83lbs injectors
£100
Rocker cover
£40
7.5 rear diff standard no knocks or whines
£150
prop with new center bearing
£40
brand new calipers front and rears
£250 with standard discs and yellow stuff pads as new only done 1200 miles.
airtec 70mm Rs 500 intercooler
£150 nearly new
airtec 60mm radiator
£150 nearly new
airtec turbo cooler (new unused)
£60
full 3''stainless mongoose system with 4'' outrolled tip (v band release on downpipe with lambda sensor.
£150
full set of floflex polybushes
£100
black samco set (newly new) t3 3 door set
£180 for all 3 sets
Loads more parts will post them up as I think of them.
parts sold;
coil overs
front bumper
bonnet
grill
rear quarter windows
scuttle panel
washer tank
sunroof
044 pump
gearbox
wiper arms
mirror triangle covers
Charlie
4x4 crank
4x4 rods
wrc shells
2wd sump
£1500
2wd head with new:
valves
isky valve springs
INA followers
bd15 inlet
£800
£300
£100
Rocker cover
£40
£150
£40
£150 nearly new
£150 nearly new
£60
£150
£100
£180 for all 3 sets
parts sold;
coil overs
front bumper
bonnet
grill
scuttle panel
washer tank
sunroof
044 pump
gearbox
wiper arms
Charlie
T5 gearbox good condition no knocks or whines £350
7.5 rear diff standard no knocks or whines £250
prop with new center bearing £60
brand new calipers front and rears £350 or £400 with standard discs and yellow stuff pads as new only done 1200 miles.
gaz coilovers as new done 1200 miles £350
airtec 70mm Rs 500 intercooler £200 nearly new
airtec 60mm radiator £180 nearly new
airtec turbo cooler (new) £80
Charlie.
Charlie.
Hi,
I'm after...
A good parcel shelf (original non folding with first aid box)
A good foam mat from under the boot carpet
Both sides small triangle plastic covers that cover the electric mirror connection point
The pressed steel part of the map sensor bracket
Can you help with any of these ????
Sean....
I'm after...
Sean....
Can I ask for the rear plastics that hold the parcel shelf up, the bit with the speakers in and the rear seat belts. also the rear seat brakets on the rear arches the bits that the rear top of the seat locks in too, Please
Hi,
I'm after...
Sean....
I'm after...
Sean....
Charlie.
