Sierra cosworth brake test. ??
Old May 3, 2010 | 08:14 PM
retro d's Avatar
retro d
Default Sierra cosworth brake test. ??
Okay so my sapp is due MOT and im unsure if I can brake test it or does it need to be a tapley test, because of the rear LSD ??.
Thanks ReTro
Old May 3, 2010 | 08:22 PM
The Youth.'s Avatar
The Youth.
for the very short time it's on there it will be fine m8
I have owned a 4x4 cos for 11 years and they have all gone on the tester with no problems at all
steve
Old May 3, 2010 | 08:24 PM
j6kyt's Avatar
j6kyt
2 or 4wd, 2wd on rollers, 4wd on the road, unless the mot place has the new type rollers which can do 4wd cars.
Old May 3, 2010 | 08:51 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
most places have rollers that can spin both wheels anyway i asked about this when i had mine done as i have a gripper and its very aggressive almost locked but they can do it with a tapping meter instead
Old May 3, 2010 | 09:04 PM
retro d's Avatar
retro d
Its a 2wd and the place I get it done they can do a bind test on both wheels but it also does single, on the safe side I will stick to the combined roller or just a simple tapley.
Old May 3, 2010 | 09:14 PM
ajamesc's Avatar
ajamesc
If u only have a standard cosworth lsd in your car i wouldent worry about it to be honnest i only worry about mine as it sounds like the thing is going to rip out the floor lol but when i had the standard diff i had it brake tested normally a few times dident do any harm but as i said if u are worryed ask them to do it with the tapping meter but then they will have to drive the car!
Old May 3, 2010 | 09:22 PM
retro d's Avatar
retro d
Cheers Fella, yeah just standard diff it would be good to brake test it cause I want to see how good they work lol.
Im going to just get the combined test on the rear and I can still do the fronts normal anyway.
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
martynhomer01
16
Aug 4, 2015 09:55 PM
