brake warning issue
Old May 2, 2010 | 09:13 PM
JoeRS22's Avatar
JoeRS22
Unhappy brake warning issue
can anyone help me, ive got a problem where as every second or third press of the brake pedal and me red brake warning light and abs light comes on, with this something runs as engine dipps in rpm, any ideas????
cheers joe
Old May 2, 2010 | 09:38 PM
bad boy rs's Avatar
bad boy rs
could be a dodgy earth mate, didnt you say you had problems the other week ?
Old May 2, 2010 | 09:59 PM
JoeRS22's Avatar
JoeRS22
sorted my cristmas tree lights in middle dash but this problem has been with me since i bought the fucker last year
Old May 2, 2010 | 10:00 PM
bad boy rs's Avatar
bad boy rs
sounds like your using the brakes too much mate, you up the garages tomorrow ?
Old May 2, 2010 | 10:02 PM
phil_focus's Avatar
phil_focus
take it you've checked the obviouse like fluid level and then the brakes arent siezed and work ok?
could well be a switch or dirty sensor. perhaps wheel sensor for abs as the abs light is coming on?
Old May 2, 2010 | 10:12 PM
JoeRS22's Avatar
JoeRS22
paul mate spent 5 hours earlier.
phil focus - fluid is fine and the brakes have been changed , i changed all the relays under glove box for spares no joy, could it be pressure switch on brake unit itself??
Old May 2, 2010 | 10:35 PM
phil_focus's Avatar
phil_focus
i'm not very knowledgable about the electronic side of braking systems but this problem does sound like an electronic wiring/sensor fault or maybe even dash light fault...not ruling anything out here
if there is a pressure switch then maybe that.
Old May 2, 2010 | 10:41 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Didn't your brother keep the abs units and ecu from his saph?
Try one or the other until you find the fault. Can't see it being a wheel speed sensor as that would bring the light on as soon as the ignition is switched on and will stay on or bring the light on as soon as the car moves if one isn't reading.
Old May 2, 2010 | 10:44 PM
JoeRS22's Avatar
JoeRS22
gary i have another pump unit, ecu and distribution block, just waiting for you to come and sort it
Old May 2, 2010 | 10:52 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Just try the ecu first, it's the easiest to do just on top of the engine ecu on the bracket.
If that don't work, there's a pressure switch on the main pump. Just swap that over, if you don't want to do that, just swap the entire unit over, piece of piss to do. Same as the valve unit on the n/s inner wing, pretty easy.
Old May 2, 2010 | 11:22 PM
jon@work's Avatar
jon@work
How many ABS relays have you got behind the dash? I could understand and explain your issues if it's got a later 4x4 ABS loom with 3 relays, as opposed to the earlier 3 door and 2wd saff ABS looms with 2 relays.
Old May 3, 2010 | 12:12 AM
carl/saff's Avatar
carl/saff
SIERRA RS 4X4 COSWORTH
Sounds like a failed relay ..... would test them first ....... buddy
Old May 3, 2010 | 08:13 AM
JoeRS22's Avatar
JoeRS22
its a 2wd, yesterday i changed the pink relay, green one grey one and a 70amp black one, no joy, as said above think im gona move onto abs ecu and brake unit itself...
yatta
May 21, 2016 10:31 PM
wattie
Sep 16, 2015 11:34 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
