2wd quickshift fitting
Old Apr 30, 2010 | 05:56 PM
PDH11R's Avatar
PDH11R
Default 2wd quickshift fitting
to fit a quickshift in a 3dr cossy do you have to take the box out or can it been done with the box in place cheers
Old May 2, 2010 | 01:08 PM
Can be done by undoing rear mount and dropping box as low as you can.
Old May 2, 2010 | 03:03 PM
Alvyn's Avatar
Alvyn
you have to drop the gearbox mount bolts and also may have to remove exhaust for the box to drop far enough to get to the bolts on the box to remove the selector stick!
Old May 2, 2010 | 03:43 PM
Tev's Avatar
Tev
as above but personally i wouldnt bother, ive had a quick shift on my t5 n it made hardly any difference, the t5 cant be rushed,
Oct 9, 2015 07:38 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
markk
18
Aug 17, 2015 05:19 AM
155lee
Aug 14, 2015 11:21 AM
lockie
Jul 31, 2015 10:03 PM
