Our New Turbosmart Product Range!
Old Apr 28, 2010 | 04:19 PM
James @ M Developments.'s Avatar
Default Our New Turbosmart Product Range!
Motorsport Developments are pleased to announce that we are now official Turbosmart dealers and would like to take this opportunity to introduce you to some of their product range.
Products listed below are in stock and available for next day delivery - please contact us for more information.
Turbosmart products have proven themselves worldwide and on some cars that you may be a little more familiar with such as the Car Planet Racing Mitsubishi Evos and the Roger Clark Motorsport Subaru Impreza, both regularly found on the podium at Time Attack and Ten Of The Best!
"Boost Tee"
This lightwight anodised aluminium piece is a great entry level solution to boost control with many benefits over a bleed valve. Using a spring loaded ball bearing inside the unit means that the valve only starts to bleed air away from the actuator once a preset pressure has been reached. This eliminates the 'lag' experienced with a bleed valve which permanently bleeds air off. As easy to fit as a bleed valve and even comes complete with a billet aluminium mounting bracket!
Price £52.81
"E-Boost"
This compact unit is capable of controlling up to 40psi boost pressures as well as being simple to install and setup. It offers two switchable preset boost levels as well as offering boost correction factor to eliminate boost creep/drop off at high rpm! The 3 section display offers adjustable brightness can be configured for PSI, KPa, or BAR and will flash to warn of over boost, shutdown or rev limit. This allows the unit to be used as a boost gauge, tachometer or a shift light!
Dimensions: W:80mm H: 25mm D: 95mm (can mounted within a 1/4 DIN size opening)
Maximum Boost Level: 40PSI / 2.72BAR.
What’s in the box: e-Boost STREET control unit. Wiring loom + installation kit
Solenoid with mounting bracket and vacuum fittings, vacuum hose and hose clamps
Price £249.99
"E-Boost2"
Designed to mount in place of any 60mm gauge or easily mounted in place of a vent in the dashboard, the E-Boost2 is a phenomenally capable boost controller offering the following features:
Boost Levels: up to 6 levels of boost.
Boost on Demand: provides instant overtaking power at your fingertips
Gear-based Mapping:set a different boost for each gear!
Adjustable Boost Levels: program boost against TIME or RPM.
Aux Output: fully programmable; controls water spray, methanol or nitrous injection.
RPM Compensation: eliminates boost drop-off at high RPM.
Peak Hold/Max Boost Recall: monitors boost and RPM.
Gate Pressure: eliminates wastegate creep.
Overboost Shutdown: provides added protection for your engine .
Display: programmable, can be configured to KPA, Bar or PSI.
Auto Dimming: with backlit buttons for hassle free navigation.
SUPPLIED WITH:Solenoid, mounting bracket, hoses, fittings, all the necessary installation hardware, comprehensive user manual.
Price £399.99
"Solenoid"
We also offer replacement solenoids for the E-Boost controllers, however, these can also be used by themselves alongside an aftermarket ECU for boost control. One of the only solenoids on the market specifically made for this purpose it is the preferred unit of many tuners!
Kit includes the solenoid with wiring, screw in nipples, mounting bracket and anti vibration mounting.
Price £78.67
"FPR 800" Fuel Pressure Regulator
The Turbosmart range includes a fuel pressure regulator capable of handling 800bhp! Made from lightweight with an anodised finish, it looks as good as it performs. With 1/8NPT ports and adjustable base pressure between 30 and 70psi it operates with a 1:1 ratio. A mounting bracket is included for ease of fitment.
Price £140.94
"Ultragate"
The Ultragate 38mm is a small unit that packs big features! It is capable of providing accurate boost control on most road going turbocharged cars as well as offering great looks for a sensible price.
SUPPLIED WITH: 7 psi spring (fitted), valve seat, 2 x stainless steel gaskets, mounting bolts and 2 x 1/8 NPT vacuum fittings.
Price £259.55
Blow Off Valves
Turbosmart Blow Off Valves are designed to make your vehicle more responsive through gear changes whilst protecting your turbocharger from damage:
"Kompact"
The 25mm Turbosmart Dual Port vents both to the atmosphere and back into the air intake. Ports with sequential timing allow quieter operation during normal driving, while getting all the benefits of a atmospheric venting BOV under race or hard use conditions. The valve is easily converted to a full atmospheric or full bypass unit by using supplied port blanking plug.
Price £166.79
"Race Port"
The largest and the highest-flowing BOV in the Turbosmart range features an oversized inlet port at 49mm and a quick-release V-Band clamp. It provides greater performance through faster turbo spool-up from idle and reduced turbo lag between gears. A must have on high boost application vehicles!
SUPPLIED WITH: Quick-release V-Band Clamp, Aluminium Weld Flange, Swivel Nipple.
Boost Gauge
A fantastically accurate gauge with great looks at an unbelievable price!
Featuring simple mechanical operation, a black face with silver bezel, bright backlighting and vacuum through to 30psi pressure range. All installation and mounting hardware is included!
Price £35.19
AND we will be offering a 10% discount from all the above listed prices to Passionford members!
Old Apr 28, 2010 | 06:37 PM
Dicko&Vacant's Avatar
Dicko&Vacant
some good stuff there at decent prices
Old May 2, 2010 | 07:59 AM
Stu @ M Developments's Avatar
PassionFords Creator
BTTT
Old May 2, 2010 | 09:55 AM
pieterjan's Avatar
pieterjan
Hi
Is the 38 mm wastegate good for 550bhp?
