L8 cosworth management SOLD SOLD
hi here i have a L8 cosworth managment conversion for a rs turbo. The ECU has the chip in to run coil pack. The management it ready to bolt on.
L8 ecu with coil pack chip.
L8 wiring loom
Coil pack kit.
New bosch 803 injectors
New throttle postion Sensor 4wd
New Air temp Sensor
New coolant Temp Sensor
New Crank Postion Sensor
New 3 Bar Map Sensor
New Ignition Amplifier
cosworth throttle body
throttle cable and bracket
Sierra bottom pully
cam bracket
crank sensor bracket
alternator bracket bolts and belt.
only think i can see missing is idle speed control valve. i may of missed bits off.
There is a invoice for the sensors and and injectors.
£660
L8 wiring loom
Coil pack kit.
New Air temp Sensor
Sierra bottom pully
cam bracket
£660
