Turbo Ka Help needed!!!
Old Apr 27, 2010 | 02:28 PM
Merlin2503's Avatar
Merlin2503
Default Turbo Ka Help needed!!!
Got what i was informed to be a mk5 escort RST engine to put in my Ka at the weekend, but turns out its a mk3 engine.
Not properly clued up on this, but from what we've found the engine wont bolt onto the current Ka box, and the engine mounts are totally different to that of the Ka.
Now, from the research i did, there are three mounts, two on the box, one in the engine bay on the O/S.
Seems none of these lines up what so ever for some reason as all the mounts are in different places.
Question, was there a difference in the mountings between a mk3 and a mk5? Or am i just being a dimwit and missing something blatently obvious?
I have been given, literally everything to do this conversion with, but was going to stick with the standard Ka box.
Any help would be appreciated as i'd rather not sell the engine and go back to a standard Ka engine
Old Apr 27, 2010 | 02:30 PM
fiend's Avatar
fiend
MK5 Escort RST engine?
Old Apr 27, 2010 | 02:37 PM
Merlin2503's Avatar
Merlin2503
You sound confused? This is what i was told the engine was, later turned out to be a Mk3 Escort RST engine.
Old Apr 27, 2010 | 02:48 PM
GaryHurn's Avatar
GaryHurn
you will want a fiesta rs turbo engine for the ka that uses efi not mfi
it be got working with mfi but its alot harder
Old Apr 27, 2010 | 02:54 PM
Merlin2503's Avatar
Merlin2503
Please explain?
Thing is, i spoke to alot of people that said it was a relatively easy (ish) conversion to do, all that was needed was a new mount kit for the O/S or a bit of home DIY on in, other than that it was a case of attaching the RST engine to the current Ka box.
scottyp1989's Avatar
scottyp1989
you mean mk4? didnt think there was any difference between mounts
Old Apr 27, 2010 | 03:00 PM
bythomson's Avatar
bythomson
get an rst box with slip diff or when boost comes on when cornering could be a bit hairy is there not a ka owners club that could help out ... the ka is the similar engine as a mk1 fiesta and if they can fit in there then you should be able to do it relativly easy
Old Apr 27, 2010 | 03:28 PM
silky16v's Avatar
silky16v
Get on That!
get on over to www.fk-oc.com and ask on there i wasn't aware that the engine was a direct fit for the Ka IB5 gearbox
Old Apr 27, 2010 | 03:36 PM
isaac james sherwood's Avatar
area six 2.1 zvh ford ka
I have done many ka engine conversions you can get the mounts from a company called track designs i made my own i have also done zvh and zetec aswell all using the ka ib5 gearbox and rs turbo lsd and ka shafts, using the ka box you can keep two of the ka mounts, and rs turbo n/s engine mount modified to fit, it is better if you use efi fiesta rs turbo engine with ofab management, but you can stay erst if you want it just makes your life a little bit harder, pm me if you need anymore info!
Old Apr 27, 2010 | 03:37 PM
sorry modifie o/side mount lol
Old Apr 27, 2010 | 03:48 PM
AaronsKa's Avatar
AaronsKa
for the CVH you need the later gearbox from the duratec engined Kas so the starter is in the right place.
Old Apr 27, 2010 | 04:01 PM
starter needs to be at the back,
Old Apr 27, 2010 | 05:00 PM
AaronsKa's Avatar
AaronsKa
on a zetec they are at the back yeah.. cvh is at the front
Old Apr 27, 2010 | 05:05 PM
GaryHurn's Avatar
GaryHurn
on the cvh the starter will not fit on the back due to the shape of the block, i had the section cut out of the bc box and welded in on the ib5 (rest of the bell housing is the same) this will allow the fitment of the cvh starter, if how ever you go zetec the starter will fit on the back
if you dont want to have the box welded then get a duratec ka gearbox as this will fit and has the starter on the front already
i have done 4-5 rs turbo/zvh conversions i have the wiring diagrams here if needed for using ofac or ofab, as said above get the mount from track designs (joey is a top lad)
regards
gary
Old Apr 27, 2010 | 06:58 PM
AaronsKa's Avatar
AaronsKa
Gary you should have finished your Ka!
big_Rad
Sep 15, 2017 09:36 AM
muz
Aug 16, 2015 12:57 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
