heated windscreen wiring
hi
i have purchased a heated windscreen wiring loom, relay and switch, now this is not to go into an escort but i am retro fitting it into my nova
just need some help with the wiring can you tell me what wire is what ?
the big red one will be 12v+
i assume this plugs into the rs turbo car loom or fuse box???
IIRC
Red - permentant live to aux fuse box on battery
Black/yellow - live when ignition on
Grey/yellow illumination for switch light
Blue/yellow engine running light
The black/purple wires go to each of the two circuits in the screen.
Feel a bit sorry for that loom - being demoted from an Escort to a Nova
IIRC
i was thinking more an upgrade
cheers anyways
what is the engine running light????
Hmm - I'll beg to differ on the upgrade; - unless you mean you are significantly increasing the value of your Nova by adding a few feet of copper wire and a relay
The blue/yellow is an engine running signal so the relay won't switch on and drain the battery without the engine running. The light bit was a typo...
BTW don't be tempted to connect that right wire straight to the battery without the 60A fuse. Unless you like loom fires that is...
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
