Master cylinder - ABS
Will it ever end !!!!!!!
I am going to remove the ABS from my Series 2.
I need to confirm which Master Cylinder i need ? Also what bore size as well ? I assume its some non abs cylinder but is there a replacement from another car I can use (Series 1 or XR3i?)
Hopefully someone can help - cheers
Standard ABS master cylinder will do fine. Just remove all pipework to / from ABS modulators and you'll be left with a bare master cylinder and 2 T-pieces on the inner wings. Make up pipes to join master cylinder to T-pieces and job done. Piece of piss really.
