Braking Escort RST-upgrade
Old Apr 22, 2010 | 07:30 PM
F_M_F_M's Avatar
F_M_F_M
Default Braking Escort RST-upgrade
Good night
I'm new here and have difficulty writing English, so I use an online translator. I apologize.
I am possessed of an Escort RS Turbo S2 1988, and I'm changing the braking system;
Front -> Disks 283mm sierra cosworth 2wd + 4wd calipers
Rear -> 273 discs and calipers sierra 2wd
My questions are as follows: switch the master cylinder and a servo for a higher capacity?
Remove ABS? Yes, not ....
What do you advise in this case?
I thank you for your willingness to help me.
Thanks
Old Apr 22, 2010 | 07:43 PM
studabear's Avatar
studabear
retain master cylinder, remove abs
fit a bias valve for the rear brakes, or at least make sure the rear load compensators are correctly adjusted
Old Apr 22, 2010 | 08:01 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Good advice from studabear about the bias valve
Old Apr 22, 2010 | 08:03 PM
studabear's Avatar
studabear
Personally I wouldn't bother with the rear disc setup ther than for cosmetic reasons
My car stops well on 2wd discs an 4x4 calipers with correctly adjusted rear shoes, I don't see the point fitting rear discs only to have to dumb them down with a bias valve
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
