Hi mate,what's a 'st' phase sensor??,do you mean the sensor inside a cosworth dist?.Buy a 1 new from a fiat dealer or get 1 off a scrapped Fiat tempra,2.0 tipo,Lancia delta int.,hf turbo,while your there also grab the idle valve,engine sensors,FPR and the dry coil,much better that the Ford oil filled 1.
He means the sensor from a small turbo that goes where the dizzy goes on the big turbos, there totally different to the phase sensor inside the dizzy on big turbo cars.
