Pick this up last weekend and starting on sorting the shell asap.New slam panel ordered to sort out the damaged one.Sealers to be removed from underside and engine bay and then to be shot blasted.
Thanks guy's as for spec not too sure at the min still looking into to what to do on this end main concern at the min is to get the shell done and resprayed.But any info on the engine spec would be great as i want to be fit to drive this on the road but have good power to but don't want to loose to much of comfort side of things.
Started to take the sill's down to bare metal as when lo@der had this he noticed a rust patch on the nearside sill.And as i have two new sill decided to see if it was that bad to fit these but to my surprise i can't belive how solid this shell is i did read on post be4 i got it that it was very clean.Im going to weld in a peice of a sill but only where the hole is as shown in pic as it solid the rest ot the way.
Excellent stuff cossiedevil, looks alot better already from when Jay had it up for sale. If i where you id put it back to standard as it will always fetch good money when and if you go to sell it. Have you running gear for the thing? good luck with it. Best color by the way with orange front indicators all the way
Well dec no engine or running gear sorted just yet but my mate in england is working on this.More concered on getting the shell all done and sprayed so i can move to my other shed to start rebuild.As i need to finish the rs2k.And yes it is staying white lads.
Small update moved the car to my other shed so i can work away on it.Have both sill's down to bare metal very happy as nothing much to worry about.New front panel got from duncan at automotiveunlimited ready to fit made another set of rollover jigs so the car is on this wings are off ready to be rolled into wrc spec ones new boot and doors are to be with ford sometime today aswell.my plan here is to make it look like stians hafengen wrc escos as i like the look and colour he had it.A few pics of where im at.
and the most important part the paint have to love that colour well i do anyway.....
