cambelt change
Old Jan 13, 2005 | 05:11 PM
boost mad's Avatar
boost mad
Default cambelt change
how easy is it to change a cambelt on a 1.8 diesel fiesta? and what other parts ( if any do i need to replace ). how long to do
Old Jan 13, 2005 | 06:19 PM
boost mad's Avatar
boost mad
bttt
Old Jan 13, 2005 | 07:38 PM
boost mad's Avatar
boost mad
only 6 ppl have looked. someone must no. bttt again
Old Jan 13, 2005 | 08:08 PM
Travis's Avatar
Travis
It depends how old it is really, the older ones have two seperate belts.One for the camshaft and one for the injection pump. Its not too bad a job if you are fairly compotent. I would suggest borrowing a timing pin kit and data book if possible. The later ones are alot easier as they only have a pump belt.Also I would advise getting the proper kit aswell which includes the relevant tentioners/idler pulleys. Hope that helps.
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
