escort not starting when its get hot
Old Apr 20, 2010 | 07:17 PM
nadcoss's Avatar
nadcoss
Default escort not starting when its get hot
right i got a erst zvh starts fine but when it gots hot and u stop it wont start intill u leave it to cool down for a bit any one else had this prob? take it its to do with the starter, i have heat rapped the down and pipe and that is there any thing else i can do, is this a common fault, cheers for your help
Old Apr 20, 2010 | 07:29 PM
turbobill's Avatar
turbobill
have you tried heat wrapping the starter motor??
also there arre heat shields you can buy which protects the starter motor
Old Apr 20, 2010 | 07:36 PM
teamfatboy's Avatar
teamfatboy
Frog Tosser
replace the cable from battery to starter, job done! its a bad earth problem
Old Apr 20, 2010 | 07:45 PM
nadcoss's Avatar
nadcoss
ok thanks will have a play at the wknd
Old Apr 20, 2010 | 08:19 PM
martysmartie's Avatar
martysmartie
Does it turn over as if it does it WON'T be the starter.
Martin
Old Apr 20, 2010 | 09:02 PM
rspickup's Avatar
rspickup
Its not an earth problem, this is very common on rs turbos, cvh,zvh etc.
Its called heat soak, the manifold and down pipe get so hot the starter motor cant handle it, there are a few ways to remedy this.
Heat wrap your down pipe, get heat shield for starter but they are hard to find
Upgrade your starter to a zetec or 1800 diesel one, if you do upgrade it, you would still benefit heat wrapping ya down pipe.
hope this helps
Vincereese
Jun 1, 2023 09:14 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
