focus st170 upgrade, ABS SENSOR
Old Apr 19, 2010 | 05:19 PM
airzfocus's Avatar
airzfocus
Default focus st170 upgrade, ABS SENSOR
just bought st170 brake upgrade for my 1.8 focus, hubs, calipers, disks st hubs come with abs, my car hasnt got abs, is there any way of rigging this up or will my car have the plug just to plug n play?
also will my drive shafts fit into st hubs?
and does anyone know the disk size of the st170 cheers
Old Apr 19, 2010 | 05:50 PM
TomStarkey's Avatar
TomStarkey
Front disks: 300mm diameter 24mm thick.
Rear disks:
280mm diameter 10mm thick.
Old Apr 19, 2010 | 07:36 PM
airzfocus's Avatar
airzfocus
Rear disks: 280mm diameter 10mm thick.
cheers m8
Old Apr 19, 2010 | 08:03 PM
tarmac terriost's Avatar
tarmac terriost
your best bet is just use the brake disc, calipers and brackets as they will fit the std hubs but might need to some spacers on the bolts for the carrier.
as for the hubs fitting the driveshafts on you car i dont think they would as your running either ib5 or mtx75 gearbox and st170 runs getrac 6spd.
to get yours to run abs will need the abs pump and module will need looms sensors etc so not really worth doing as will cost a fortune to get fitted and for the parts.
the st170 disc are 300mm,have a set on my mrk2 mondeo 2.0 16v with mrk3 mondy calipers also run abs too the power they generate can throw you through the front screen need them a few times when people have pulled out on me
15
Oct 7, 2015 03:43 PM
RSBryden
Sep 6, 2015 08:39 PM
gavt123
Sep 5, 2015 10:03 AM
Fordmad!
Sep 4, 2015 01:42 PM
Sep 3, 2015 10:49 AM
