Standard rads for rs turbo s2?
Old Apr 19, 2010 | 09:11 AM
jacko82's Avatar
jacko82
Default Standard rads for rs turbo s2?
I was wondering if anyone knew the life expectancy of a alloy rad like a pace one for example. Im fed up of the standard "made up of wet toilet paper" rs radiators. Like my exhaust for example, full stainless, have not needed to replace any of it. In my old car it was at least one section of exhaust a year. I can only think an uprated rad would be better anyway, but, can anyone tell me if they last well for the extra cash? ta
Old Apr 19, 2010 | 10:41 AM
PeterD's Avatar
PeterD
I ran pro alloy stuff on my last RST's, never let me down. Had an S1 with the same kit on it that kept punching a hole in the cooler (s1 set up doesnt have the fans mounted between the rad and cooler so they rub a bit.
However I let PA know and they took it back and sorted it, even replaced it and made me a "anti rub device" (aka bit of rubber round the cooler) that was the second time it happened, so even when it did terminally fuck up they sorted it.
Cant recommend them enough.
Old Apr 19, 2010 | 11:00 AM
jacko82's Avatar
jacko82
cheers PeterD, those standard rads are pants. How are they for fitting?
Old Apr 19, 2010 | 11:46 AM
PeterD's Avatar
PeterD
Easy enough to fit fella, if you can change your std one you can fit one of those.
Pete
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
A.t.p
Aug 15, 2015 11:37 AM
track.focus'd
Aug 12, 2015 05:53 PM
