cossie turbo damper
Whassup
how important is that piece? i'm running my car without that damper at the moment,
so what damage will it bring on a short or long term period?
just running on standard bhp if that makes any difference?
so what damage will it bring on a short or long term period?just running on standard bhp if that makes any difference?
2wd or 4wd ? I believe the damper is recommended on a 2wd to save your exhaust studs from snapping, but it is apparently not required on a 4x4.
I am sure someone else will confirm or deny this though.
Very! Can cause your exhaust manilfold studs to crack, not nice to replace those! And also stops vibrations throughout the rev range, especially in the mid range area. The std ford damper is the one to use! BHP has nothing to do with the need for one when using a 2wd exhaust manifold.
Whassup
Originally Posted by SPADGE
Deffo need one on a 2wd manifold!
I have a complete one you can have for 25 quid if you want it?
Cheers Spadge....
Cheers Spadge....
twice
Billy_RS
16
Oct 11, 2025 09:41 PM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
