collins monitor 260 delivered can take to pod
As a few threads below i bought this from ajc but it wont work on l6 unless its been converted to l600, or i need to buy an l8 or p8 then new chip etc etc then a loom for knock sensor lambda etc not worth the hassle at the moment for me
Hi mate,
Can you post up a few photos of the monitor?,when you say you'd need a new eeprom does it have to be a specific Collin's job??.
Does this version of monitor also temp. adjust the fuelling and timing internal maps,like the Pectel monitor with red and green buttons?.
Thanks.
Thanks.
Hi mate,
Thanks.
Thanks.
no, msd chips can work and so on just not on an l6 unless its converted with a pectel board, you would have to check with stu first if your chip is compatible but they can work with it.
its a pro version so it can adjust fuel and ignition all the details are still on collins site
will do, its in good condition, you would have to check with stu for deffo ring and quotee chip serial no. but i would of thought yes as youve got a pectel board so essentially you have an l600 which is whats needed
pics to follow cheers
Steve Escos
Oct 1, 2015 06:57 AM
