Converted To Ofac Efi Wont Rev Past 3000 Revs Help Plz
Apr 17, 2010 | 09:13 PM
i have converted a s1 escort cabriolet to fiesta rs turbo efi ofac with the efi loom runs amazing only thing is it wont rev past 3000 revs help
Apr 18, 2010 | 11:09 AM
Apr 18, 2010 | 11:59 AM
a lot of the usual people with the answers are prob at central day
Apr 18, 2010 | 06:25 PM
im not going thats why im asking for help
Apr 18, 2010 | 07:36 PM
Quote:
Originally Posted by
arbinder
what he means is the people who would normally answer your questions are proberly at central day hence not replying on the computer
Apr 18, 2010 | 07:44 PM
Apr 18, 2010 | 07:48 PM
does it pop or miss or just wont rev past 3k, have you checked that all the plugs are on properly and tight
Apr 18, 2010 | 07:50 PM
sometimes pops but just wont rev past 3k checked everything
Apr 18, 2010 | 07:54 PM
Apr 18, 2010 | 07:56 PM
when runnig un plug your map senser and c if the engine note changes,does it smoke at all or anything,also what breather are you running as the fiesta runs with the little one way valve in is the valve the right way round
Apr 18, 2010 | 08:02 PM
another point is how are you measuring the engine revs?
s1 or 3i rev counter will only read half iirc as ofac/ofab's wasted spark
Apr 18, 2010 | 08:04 PM
Apr 18, 2010 | 08:05 PM
cool, reading should be correct then
Apr 18, 2010 | 08:08 PM
with the map sensor off the engine sounds the same i think but when rev trys to cut out doesnt smoke and the breather im using is a fiesta rs turbo and its all fine
Apr 18, 2010 | 08:30 PM
when i dis-connect my map senser the engine note changes and it sounds like its trying to cut out,have you checked the one way valve on the breather too,also can you hear your turbo winding up at all as your exhaust might be slight blocked
Apr 18, 2010 | 09:48 PM
turbo has been set to no boost at the moment can it be the cps ?
Apr 19, 2010 | 05:25 PM
Have you definitely got the correct OFAC map sensor? They're listed on Ebay all the time with an XR2i sensor which won't register any boost.
The XR2i ones are rectangular. A proper OFAC one is sloped on the right hand side.
Will it not rev past 3000RPM when it's out of gear? Or is it only when you are driving it?
What happens when it won't go past 3000?
Apr 19, 2010 | 06:55 PM
got the right ofac sensor it wont rev past 3k on stand still dont no about driving it yet as im just finishing it
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
mondeomark
Sep 28, 2015 06:28 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
Neil Clark
Sep 8, 2015 07:06 PM
