2wd clutch cable help
Old Apr 16, 2010 | 05:02 PM
2wd saff cos @ stage 3's Avatar
Default 2wd clutch cable help
how do you remove it please??
Old Apr 16, 2010 | 05:07 PM
grcossie's Avatar
grcossie
Pull the cable from clutch arm end, then you will get it off in that end, then you take it off on pedal end, easy job
Old Apr 16, 2010 | 05:19 PM
simple as that?? jus pull it lol
Old Apr 16, 2010 | 06:13 PM
Steve Escos's Avatar
Steve Escos
You might want to wedge the clutch pedal up before pulling the cable otherwise you will also be fighting the ratchet. However wedge the pedal and it is that easy. 5 minutes tops to swap if the car is jacked up or on a ramp.
Old Apr 17, 2010 | 12:42 PM
If you lift the clutch pedal it will release the ratchet enabling you to use your thumb to push all the way fordwards and disconnect the cable.
Old Apr 17, 2010 | 02:47 PM
oh ok didnt realise u had to wedge the pedal up, but yes car is jacked up.
thanks
Old Apr 17, 2010 | 07:25 PM
You don't need to wedge the pedal, push the quadrant forwards after lifting pedal cable comes out easy, then take off gearbox end, put box end on first, bit of tape to hold it in position repeat pedal action.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
