repost of the post you've made in the last 5 minutes?
ok, 3 or 4 times now htis has happened, the next time it does i'll get a screen shot of both pages but you basicly:
reply to a post and the screen goes blank
the little thing in the corner says "done"
but nothign on the scren at all
press f5
the message "you need to resend the info" or words to that effect appear
so i press yes
then it says "you've already sent the same message in the last 5 minutes"and then the forum goes back to normal again
anyone else?
press f5
so i press yes
anyone else?
to be fair, it's not happened today at home or at work, it was only yesterday that was causing a fair amoutn of problems stu
if it occours again i'll put it in this thread
