Overheating...
Old Apr 15, 2010 | 07:28 PM
KW-rscos's Avatar
KW-rscos
Default Overheating...
Think I have an airlock in my cooling system, what is the best way to remove it? Will it require a full drain and refill of the system?
Old Apr 15, 2010 | 08:15 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
It does help if you say what car it is
Steve
Old Apr 15, 2010 | 09:30 PM
KW-rscos's Avatar
KW-rscos
Sorry yeah, its an R reg Escort GTi.
Old Apr 16, 2010 | 07:26 AM
KW-rscos's Avatar
KW-rscos
anyone?
Old Apr 16, 2010 | 07:33 AM
KW-rscos's Avatar
KW-rscos
double post
Old Apr 17, 2010 | 03:16 PM
So long as the highest point in the cooling systems pipe is nice and clear where it goes back to the expansion tank it should self bleed as it cools down.
Old Apr 17, 2010 | 03:26 PM
RichieST's Avatar
RichieST
Should self bleed itself. Try getting up up to temp and give the water pipes a good firm pump with your hand, that should help shift any air that may be trapped.
