my oil pressure on hot engine with full throttle to the rev limiter is 37 psi !
I am affraid it is too low, the car runs perfect, engine is quiet but i dont know whats happen. Can i drive with 37 psi to the rev limiter?
At hot iddle my pressure is 22psi
Are you using the same sender that was with the gauge in the audi ?
37 doesn't sound that bad, I would have expected a little higher maybe 45psi.
