Any structual steel engineers on here ?
I need to get a bit of clarification about a roof im doing at the moment.
My architect has specced a set of roof beams very early on in my plans, but from what I know and what people have said when ive been pricing the steel seams a little large for the job...........................so,
Can anyone work out what size of beams I should be using?
the roof area is 86m2 and the building is 10m x 8m
the steel sizes ive been given to use are 203 x 133 x 30 @ 10m lengths x 3.
I'll try and give a few answers to what people will ask.
a, no i dont want wooden trusses of any sort.
b, I know over spec is great for strength but i would like to ensure im using the correct size for the job, as over size = over cost !
c, I cannot get hold of the architect, and have been unable to for 3 weeks now
d, the roof will be covered in Marley Modern concrete roof tiles.
Cheers all
Mark
Cheers all
Mark
Mark
When specing stuff architects and indeed structural engineers will ALWAYS over spec items.
Simply to make sure it doesn't go wrong, the consiquences of it going wrong are not worth considering in terms of the potential human cost and for them they will have PI (Personal Indemnity) insurance which is costly to claim on and will effect their lively hoods.
Now - simply looking at the info you have given the reason for the size of steel is the span. 10m is a fookin long way.
I used a structural engineer when I did my house - he charged Ł50 for some similar calculations, I'll happily give you his details.
He will work from sketchs and a description of the work and produces a good report.
I was very happy - all done over email too.
PM me as I wont get back on tonight.
He will tell you what you NEED rather than anything else based on the steel I used.
Jake
Jake
Just going on - those steels would weigh a ton.
I had a 203x102x26 3.2m long and it weighed 100kgs or there abouts.
I paid about Ł90 for that delivered and it took a few of us to lift it into place, I bet they weigh a fair bit more than that.
What have the architect specced for it to sit on??? (are the blocks in your garage walls dense blocks or aircrete type blocks?)
J
J
J
J
the blocks are solid 7.3n 140mm all the steel sat on pears.
the quotes im getting are not the end of the world, but everything mounts up if your over speccing the whole job.
British UB comes in 25 and 30 (edit: 25 and 30 for that size of beam). For that span i would have thought that 25 would be ok but it obviously depends what sort of wether loading it has to withstand. Maximum snow ice depth etc
rog
Sep 4, 2015 12:10 PM
