Radtech intercooler
Old Apr 14, 2010 | 07:38 AM
aronzvh's Avatar
aronzvh
Default Radtech intercooler
Hi guys is the radtech intercooler worth getn n will it fit straight on, dont wana be cutting bumper n stuff? Easy fitting or needs modding to fit on 90 spec bumper?
Old Apr 14, 2010 | 10:48 AM
conor.rst's Avatar
conor.rst
Get a grs
Old Apr 14, 2010 | 11:19 AM
Rob_DOHC's Avatar
Rob_DOHC
I had a GRS and it was very good, bumper didn't need modding but i did space my rad further back to sandwich the fans.
I now have a radtec which isn't fitted yet (as the car is in a million random pieces) but it looks very good, same sort of size as the GRS and with a simular number of cores so i really can't see there being much difference in ACTS between the two.
Rob,
Old Apr 14, 2010 | 11:25 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
radtec is spot on and fits perfectly with no cutting of bumper
Old Apr 14, 2010 | 12:23 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
+1 Radtec's are a great fit... might have small probs if you fit alloy rad too but only with bonnet catch, same as GRS/Airtec etc.
Old Apr 14, 2010 | 03:55 PM
Karlos G's Avatar
Karlos G
Balls Deep!
+1!
Back to back dyno testing was done against the GRS and it performed ever so slighty better
Old Apr 14, 2010 | 06:21 PM
RSandy's Avatar
RSandy
this 1 is the earlier generation of radtec coolers, i have the slightly newer 1, still fits just as well, only fills the complete front, and the brackets set it back on to the rad, so with the fans fitted to the front, no mods are needed to a 90spec bumper, mine didnt even need trimming even slightly
my mate has the earlier type like this, n the only issue is bonnet catch clearance, other than that, its great. later type sit back so no bonnet catch probs
Old Apr 14, 2010 | 10:24 PM
aronzvh's Avatar
aronzvh
Great will go grab that then cheers guys!
Old Apr 14, 2010 | 10:25 PM
aronzvh's Avatar
aronzvh
Great!
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
