saff shell value and price of 4to2wd
Old Apr 13, 2010 | 08:47 PM
sir nose's Avatar
sir nose
Default saff shell value and price of 4to2wd
ive found a 2wd shell to re-shell mine,it has no engine,gearbox,loom,glass and interior,its low mileage unwelded good condition bonnet needs painting.what is it worth?
what would be the better option.
1.convert a 2wd shell for 4x4 running gear.
2.ditch all the 4x4 gear and go 2wd.
what parts wouldi need to collect if i change to 2wd?
Old Apr 13, 2010 | 09:12 PM
opposite lock's Avatar
opposite lock
are the chassis rails ok on the unwelded 2wd shell? personaly speaking i would use the original running gear on the 2wd shell , whats up with your car? Get the t5 2wd box and the rest of the running gear, xmembers , shafts etc im sure someone can explain in much more detail lol . Use your brakes and suspension shouldnt be too much of a prob matey
mike
Old Apr 13, 2010 | 09:14 PM
dingla rs's Avatar
dingla rs
its only one small mod to change 2wd shell to except the 4x4 box mod on tunnel driver side ,if you look for sale section a fella selling his 4x4 bits as he converted his escort cossie to 2wd its quite a list mind diff beam crossmember shafts startermotor sump ect ...
Old Apr 13, 2010 | 09:21 PM
sir nose's Avatar
sir nose
my 4wd shell is rotten and im planning for a re-shell in the winter,my engine should produce more power than a mt75 can handle so there is more than 1 reason to swap.
any ideas on a price for the above mentioned shell?i know the fella selling will want top doller for it.
Old Apr 13, 2010 | 09:27 PM
dingla rs's Avatar
dingla rs
https://passionford.com/forum/ford-r...-2wd-bits.html
just so you have i dear what needs to be tacken off swaped
Old Apr 13, 2010 | 09:36 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
hard to put a price on a good shell, blackcos on here has a mint unstamped shell.think its 500 quid.
he also has a 4x4 flint grey rolling shell for 500 quid.
rust free shells are hard to find.
Old Apr 17, 2010 | 04:03 PM
I've seen much worse than yours, shell wise, at least you have the facilities to repair easy enough.
bobsworth
77
Mar 24, 2016 09:30 PM
Fil
Sep 30, 2015 12:08 PM
cossie330
Sep 27, 2015 04:13 PM
