squeaky front bushes?
Old Apr 12, 2010 | 11:20 PM
col93saphcos's Avatar
col93saphcos
Default squeaky front bushes?
hi,
got squeaky bushes on the front somewhere and just cant pin point which ones,sound like its coming from the shock,
any ideas what bushes can be guilty of being noisy,its just constantly squeaking!doing my head in now,
cheers again
colin
Old Apr 16, 2010 | 01:13 PM
dojj's Avatar
dojj
Resident Wrestling Legend
is it coming from one side or both for starters
and have you put new bushes in recently
Old Apr 16, 2010 | 04:25 PM
col93saphcos
seems both sides,
have only replaced springs,
all polys were greased up apart from on anti roll bar,maybe theyve dried out,
hard to pin point on my own but sounds like about coming from in the wheel arch,
cheers colin
Old Apr 16, 2010 | 05:19 PM
dojj's Avatar
dojj
maybe it's thje springs that haven't seated properly in their cups?
Old Apr 16, 2010 | 06:21 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
will almost definitely be the arb bushes
Old Apr 17, 2010 | 07:14 AM
dojj's Avatar
dojj
i wonder if the op has tightened everything while the car was still up in the air?
loosen the bolts with the car in teh air on the tca inner and outer, just a turn or so
hen drop it on the dck and tighten back up again
should hmake a difference as they will be in the normal road state with weigth on them when they get locked into palce
Old Apr 17, 2010 | 12:34 PM
The grease supplied is only to aid installation, one of the marvellous properties of poly is it is self lubricating.
A good point about the weight needing to be on the car when tightening, but you'd have stiff jerky steering if this was the case.
Spray the bushes with wd40 one at a time and drive, till you find the one that stops the noise.
rex647
Mar 6, 2022 06:20 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
