Anyone know where I can get my hands on an emulator?
Basically I'm having an absolute nightmare getting my RS Turbo mapped. Jamsport built the engine and converted it to EFI at the same time for my father 5 years ago. The car went in the garage and that was that until I recentley put it back on the road. The engine is almost run in and i rung Jamie to book it in to get mapped. He said the car was running a VW Golf G60 ecu and he no longer had an emulator to map it. Great!!. Been onto grove garage who said they might be able to do something and the boys at South Coast Performance who are getting back to me tomorrow.
No one seems to have an emulator so I was thinking if I could buy one problem solved. Either that or i've got to fork out for someone to fit an aftermarket ecu and then map it at around £1000. If any of you could help it would be greatly appreciated.
Jamsport are on here so maybe they can tell you what emulator is needed and then you can find a tuner who has one. I don't know whether a MET-16 (token cossie emulator) will have the relevant leads.
Adam Graham
Sep 6, 2015 06:04 AM
