few exhaust heat wrap questions
Old Apr 11, 2010 | 07:27 PM
stu21t's Avatar
stu21t
Default few exhaust heat wrap questions
i had some cheap exhaust heat wrap on my car for a couple of years,
it worked fine and did the job well, but made loads of mess
the fibres come off and just go everywhere.
are there any better ones out there that dont do it?
the dei looks to be the best any 1 used it? does it still make a mess?
i didnt seal the old stuff, but see that dei do a sealer for theirs so will probably give that a go this time.
http://www.nimbusmotorsport.com/Prod...=755&CATID=280
http://www.nimbusmotorsport.com/Prod...=654&CATID=280
any1 got any opinions?
Old Apr 11, 2010 | 07:32 PM
jaiscossie's Avatar
jaiscossie
I use Thermotec, not the cheapest but is good stuff, use the spray on it after to and it will last longer
Old Apr 11, 2010 | 07:46 PM
stu21t's Avatar
stu21t
http://www.agriemach.com/product_inf...roducts_id=815
copper thermotec wrap?
Old Apr 11, 2010 | 08:29 PM
stu21t's Avatar
stu21t
after a quick sniff around ebay ive found 3 options
the thermotec copper wrap,
dei titanium
or unnamed graphite impregnated fibreglass wrap
any1 ?
Old Apr 11, 2010 | 08:47 PM
jammerrs's Avatar
jammerrs
how much would ceramis coating cost? that wouldnt make the same mess
i did see some paint in demontheives that was ment to be good, didnt require any baking and was about Ł25, only came in black thoguh, if thats a problem for you!? it could be an option
Old Apr 11, 2010 | 09:01 PM
jaiscossie's Avatar
jaiscossie
This is the stuff i used
http://cgi.ebay.co.uk/THERMO-TEC-EXH...#ht_862wt_1165
Old Apr 11, 2010 | 09:06 PM
stu21t's Avatar
stu21t
i have just had my manifold ceramic coated.
waste of time really.
even on just sitting in the garage to warm up to temp the manifold got so hot i cant even tap my fingers on it.
with just the cheap wrap i could at least touch it, almost hold it.
i will be ringing the company that coated it tomorow to see what they say.
Old Apr 12, 2010 | 06:59 AM
stu21t's Avatar
stu21t
up for the morning crew
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Kam B
Sep 24, 2015 10:40 AM
cossie09
Sep 10, 2015 06:56 PM
