What tyres are you running on your cars ?
Old Apr 11, 2010 | 02:41 PM
KSA-Cossie's Avatar
KSA-Cossie
Default What tyres are you running on your cars ?
Was gonna go paradas myself.
Old Apr 11, 2010 | 02:44 PM
Staffi's Avatar
Staffi
Hated those on my Saff Kev, didn't rate them for much Grip in the wet.
Max put Uniroyal Rainsport on when he changed to 18s, great tyre i felt these were, had Eagles on my Evo and other cossie, very impressive..
Old Apr 11, 2010 | 02:59 PM
Sonic Boom's Avatar
Sonic Boom
Loving my newly fitted Hankook V12 EVO's can't rate them highly enough.
Rich
dakar's Avatar
dakar
paradas on the back and fulda,s on the front.Dont mind the fuldas at all
Old Apr 11, 2010 | 03:06 PM
dooge's Avatar
dooge
dooge
Round ones lol
iv'e got yokohama A520 tyres on mine the seam ok
dooge
Old Apr 11, 2010 | 04:51 PM
pacwest's Avatar
pacwest
Puller of the Wrench
I have some 17 inch Yokohama Advan A032-R in 235 on my 3 door.
http://www.tirerack.com/tires/tires....=ADVAN%20A032R
Old Apr 11, 2010 | 04:54 PM
RSCossieGaz's Avatar
RSCossieGaz
got eagle F1's on mine!
Old Apr 11, 2010 | 04:56 PM
Ridgey's Avatar
Ridgey
Falken Fk-452, good road tyres.
Old Apr 11, 2010 | 05:05 PM
Xrcossie's Avatar
Xrcossie
Yokahama paradas all round 215 40 17s pretty good so far, plenty of grip once there a little warm
Old Apr 11, 2010 | 05:34 PM
saph in dorset's Avatar
saph in dorset
Coulbt rate the eagle f1s high enough have got them on my saph which is my daily and after 6 months use try have still got 6/7mm of tread left ad give good grip in both wet and dry.
Will be putting them on again when I renew
Old Apr 11, 2010 | 05:38 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
I run 888's or T1R's, but I mainly use it for trackdays.
Old Apr 11, 2010 | 05:40 PM
james kiely's Avatar
james kiely
eagle f1s for me kev
Old Apr 11, 2010 | 05:45 PM
Rich_bloor's Avatar
Rich_bloor
rich_bloor@hotmail.com
i used to run 'BF Goodrich' on mine
Old Apr 11, 2010 | 06:01 PM
charlie luciano's Avatar
charlie luciano
eagle f1's gsd3's on mine
Luciano
Old Apr 11, 2010 | 06:13 PM
KSA-Cossie's Avatar
KSA-Cossie
Luciano
Evening bruv Where from jimmy ?
bad boy rs's Avatar
bad boy rs
888's on mine perfect in the dry, shocking in the wet
Old Apr 11, 2010 | 07:25 PM
Mike1's Avatar
Mike1
Toyo R1R - midway between 888 and T1R.
Used to rate the Yoko AVS Sports but can't get them anymore
Old Apr 11, 2010 | 07:55 PM
RSCossieGaz
been eventful has it!
Old Apr 11, 2010 | 08:18 PM
Moonstone Mo's Avatar
Moonstone Mo
this a road going tyre as in good in wet aswell as dry..
Old Apr 11, 2010 | 08:25 PM
bad boy rs's Avatar
bad boy rs
just a bit
Old Apr 11, 2010 | 08:30 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
i loved my eagle f1's
can't seem to get them for my lattaces
Old Apr 11, 2010 | 08:48 PM
Mike1's Avatar
Mike1
Good in wet ? Compared to F1 Asymms or Vredestein Ultracs, not as good as them. Not as noisy as the 888s and a bit more progressive
Old Apr 11, 2010 | 08:56 PM
Papillon's Avatar
Papillon
Had t1r, the last set didnt give any confidence at all, the set before was ok, strange.
Now have eagles instead
Old Apr 11, 2010 | 09:08 PM
phil_focus's Avatar
phil_focus
got falken fk452 on the front of my focus. seen 4 track days and there used as dailys and they are great!!
gonna try something else when i renew though, see if i can find something better.
Old Apr 11, 2010 | 10:01 PM
kosman's Avatar
kosman
sideways all the way!
pirelli p7000s on mine,theyve had some abuse in the dry aswell but plenty left on em.
Old Apr 11, 2010 | 10:12 PM
AndyCanning's Avatar
AndyCanning
ive got fuldas on mine .. looks good and handles well
Old Apr 12, 2010 | 07:49 AM
charlie luciano
Morning Kev I got them off my pal over in Northolt, I don't think you can get them anymore (dis-continued)
Luciano
Old Apr 12, 2010 | 07:57 AM
Rsmat's Avatar
Rsmat
toyo r888`s and toyo t1r`s
Old Apr 12, 2010 | 12:19 PM
DaveCrack's Avatar
DaveCrack
Paradas on mine, but dont drive when its wet with 2WD!
Old Apr 12, 2010 | 01:49 PM
johnandhissaffy's Avatar
johnandhissaffy
white fords look best
i got eagles f1s on front and toyo proxes on rear and handles the bollox will never get cheap tyres again ever
Old Apr 12, 2010 | 05:39 PM
HANKOOK VENTUS EVO V12, k110, all the way, faster in the wet than f1 is in the dry, seem ace on 2wd and 4wd, V quiet, grip in wet is unreal esp under braking, exactly as the tests have found, used f1 myself on various cars, still yet to be impressed, vredestein sportrac 3 masses better wet and dry, as were rainsports, but none can touch the evo v12
, have quite soft sidewalls so seem a bit less sharp to start with, until you get used to them, at sepang they lapped within 1.8 secs of dedicated track tyres on a scooby wet and dry, ie wet track tyre and dry track tyre, and after doing this and the track tyres being worn out the car was driven home on the still legal ventus v12.
Old Apr 12, 2010 | 05:45 PM
Sonic Boom's Avatar
Sonic Boom
Loving them on the back of my 3 Door should have some one the front when I get paided at the end of the month.
Rich
Old Apr 12, 2010 | 07:10 PM
105epwr's Avatar
105epwr
i use parada spec 2s,really good in the dry but not so in the wet but i dont use mine in the wet as theres no point as wheel spin in 4th is a waste of time!
Old Apr 12, 2010 | 07:40 PM
KSA-Cossie's Avatar
KSA-Cossie
Luciano
Fuck Is it gay to want a funky tread pattern.
Old Apr 12, 2010 | 07:53 PM
dakar's Avatar
dakar
Not at all mate its something i consider when i buy tyres if i,m honestalthough i do think the parada spec 2,s look bald to start with but have a mint tread pattern
Old Apr 12, 2010 | 07:57 PM
WongRS's Avatar
WongRS
kumho ku31's, love them to bits for the price, outperform alot of things twice the price!
Old Apr 12, 2010 | 08:27 PM
phil_focus's Avatar
phil_focus
my mate replaced his bridgstones with those kumho ku31's on his rx8 and even after 1k bedding them in he hated them.
mind you he wasnt keeping the car for much longer anyway lol.
Old Apr 12, 2010 | 09:27 PM
WongRS's Avatar
WongRS
ive always got on well with them, had them on my 205 which got absolute death, wet or dry and trusted them totally!
I always say, tyres are a very personal thing!
Old Apr 13, 2010 | 12:05 AM
phil_focus's Avatar
phil_focus
i totally agree with you, tyres are a very personal thing and also i feel perform VERY differently on different cars and in different sizes so all you can really do is try some different tyres till you find the ones you like.
Old Apr 13, 2010 | 06:27 PM
miller318i's Avatar
miller318i
H676 ERL
Ive just put parada spec 2's on mine, it felt a bit twitchey at first, but seemed to get better after a few miles,
