Carl Lewis treadmill
LED display computer measures body fat, hand pulse, distance, speed and calories. The cushioned running belt (120 x 40cm) makes it better than running on the road as it is easier on the joints. The speed ranges from 1-16km/h with 2 manual incline levels and comes with a 1.75HP continuous motor. There are 6 programmes including one manual setting. Maximum user weight 114kg (18st). Assembled dimensions: h153 x w66 x length 130cm
£150 Located in Essex and can help with Del within reason.
