Larger uprated diff for a 3dr cossie???
Old Apr 9, 2010 | 10:25 PM
1374lee's Avatar
1374lee
Default Larger uprated diff for a 3dr cossie???
As above I am looking into a larger diff for my 3dr.I don't want anything noisy clonky diffs like Grippa,don't want a Quaife either.
What are my options on a larger diff,where can I get one from and what sort of money please?I know Kevin Sharp had a 9" diff on his escos converted to rwd.
Will the driveshafts have to be modified or the beam itself?Any help would be greatly appreciated.
Many thanks.Lee.
Old Apr 9, 2010 | 10:58 PM
cossyking's Avatar
cossyking
Many thanks.Lee.
i got a quaife atb in my 3 door and its spot on mate
Old Apr 9, 2010 | 11:46 PM
paul16v's Avatar
paul16v
Monte 087
The 9" fits in the std 2wd beam, you have to drill 1 hole in the floorpan further over to bolt the diff mount to the car as they use a different mount, and iirc you can use a pair of the longer 2wd driveshafts.
Old Apr 10, 2010 | 12:01 AM
pacwest's Avatar
pacwest
Puller of the Wrench
Supra mk.II firs with adapters that are cheap.
Old Apr 10, 2010 | 09:10 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
9'' is an rs 500 diff i think. Rod use,s a daimler limo diff think thats a 10.5'' but u would have to pm him about beam / flange and sharft mods thats the cheap option!. If u go ford 9'' there mega money so u may as well go gripper or quaife with a uprated cwp good for 500lb ft un less u drive like a twat all the time
Old Apr 10, 2010 | 09:33 AM
1374lee's Avatar
1374lee
Is the 9" diff like an RS500 ITEM THEN,i THOUGHT THE DIFF ON A 500 WAS THE SAME AS ANY 2WD DIFF?
Where could I get a 9" diff from and what sort of prices am I looking at please?
MANY THANKS.Lee.
Old Apr 10, 2010 | 10:38 AM
Turbosimpsons's Avatar
Turbosimpsons
standard RS500 diff is a 7.5". 9" was developed for the RS500 touring cars ( i think ) you will pay about £2500 - £3000 for a 9".
Old Apr 10, 2010 | 10:59 AM
ajamesc's Avatar
ajamesc
Yeah something like that a read somewear about it being something to do with the rs500
Old Apr 10, 2010 | 11:18 AM
Mike1's Avatar
Mike1
From what I've read the 9" rear end was homologated originally for the RS200 to cope with 650bhp+ and then adapted for use in the Gp A Sierras.
They were originally plate type ZF ones at first then viscous coupling on the Mk2 design.
Think you can get 4:27, 4.09, 3.82, 3.64, 3.42, 3.25 and 3.08 ratios. Andy G uses a VC in his Focus - the advantanges of the bigger VC is that it resists the build up of heat for longer without a cooler (although you could plumb one in ) and the diff can be rated much 'tighter' than a 7.5" with nickel plates - see the big thread on rear diffs for more info from the people who know like ian sibbert, markk, Tony Ryan etc.
The diff internals are much stronger obviously on the 9" as well.
As said though, they're not cheap.
Have you thought about the Titan plated diff ( supposed to be quieter than a Gripper ) that Mike R can get hold of in a 7.5" fitment? I don't know how much power/torque you run and how you drive though
Old Apr 10, 2010 | 11:43 AM
1374lee's Avatar
1374lee
9" diff,how bloody much.Well that's out the window then.I'm looking for something to cope with 500bhp probably 450lbs/ft torque at least.I was contemplating just getting my standard diff rebuilt as the car won't be tracked,launched or driven that hard on the road.The planet gears shouldn't break if it's not launched should it?
So u think I should contact MIKE R then to see wht he has for a 7.5" diff?Like I say I don't wasnt it noisy and clonkey like a grippa diff.What size are the Quaife diffs and Grippa diffs anyway are they still standard 7.5" size?
Thanks.Lee.
Old Apr 10, 2010 | 11:53 AM
joffy's Avatar
joffy
SLOW LEARNER
bit less BHP than your lookin for but this may be some help
https://passionford.com/forum/genera...-cosworth.html
Old Apr 10, 2010 | 12:34 PM
ajamesc's Avatar
ajamesc
Thanks.Lee.
There 7.5 inch or 7 if u wont. Mines a gripper and its not that clonkey lol its fine to live with its the torque that kills them and the week bit with a 7.5 is the crown wheel and pinion i ripped all the teeth off mine in 2nd comeing off a roundabout hard so u need to up rate that aswell if u say 7.5 but u will always be on the limits of a diff that size with big torque
Old Apr 10, 2010 | 01:23 PM
1374lee's Avatar
1374lee
Thanks some good info there guys,just read the diff thread,just contacted Mike R for info on the Titan diff.
CheeRS.Lee.
Old Apr 10, 2010 | 03:34 PM
AndyPen's Avatar
AndyPen
Good move Lee - I am on my third diff remember pal - so will be watching your moves carefully
Old Apr 10, 2010 | 03:37 PM
Staffi's Avatar
Staffi
3k for a 9" Diff??? KIN-HELL.............
Lee, Quaife on my saff was superb m8....but you don't want one anyway
You're spending some pennies on that car m8.............
Old Apr 10, 2010 | 05:19 PM
1374lee's Avatar
1374lee
Pete,u have a pm m8.
CheeRS.Lee.
Old Apr 10, 2010 | 11:01 PM
wildheart's Avatar
wildheart
Its more like £4k+ for a 9" now if you can find one!
Old Apr 11, 2010 | 12:38 AM
Icekottarinn's Avatar
Icekottarinn
I am having the same problem in my Cosse 2wd.
Does anyone have further info on this 9" diff? What cars are using it?
Has anyone consider the Ford 8.8 diff from Thunderbird?
Or a BMW diff?
Regarding the Supra MkII solution, can you please give some more details? I.e. where to buy etc?
Old Apr 11, 2010 | 12:55 AM
BRAMMER's Avatar
BRAMMER
Someone that was once selling one may know a bit about them
http://fordpower.org.uk/forum/index....&mode=threaded
Old Apr 11, 2010 | 01:21 AM
Gav Diamond's Avatar
Gav Diamond
Or a BMW diff?
With regards the 8.8, i looked into this but you are still looking at £1000 for the diff (all be it brand new everything) and then you have to do a lot of modding to the beam to make it fit.
Contact Lincoln off here if you want more info as he has gone this route.
With regards the 9inch, the last time i spoke to Bara im sure they were like £3000-3500+vat
Old Apr 11, 2010 | 10:27 AM
1374lee's Avatar
1374lee
Yes they are 3.5k+vat at BARA,u do have to modify the beam and the group A diff mount is no good,there is a specificalkly designed mount for a 9" diff,I think u have to drill a hole in the body aswell to fit this diff mount.Kevin Sharp,breaking his escos in the parts section,he had the diff,now sold,he knows quite a lot about it.
CheeRS.Lee.
Old Apr 11, 2010 | 12:53 PM
Thanasis's Avatar
Thanasis
here mate,the first one with jaguar diff,the second with BMW M5
Old Apr 11, 2010 | 01:08 PM
paul16v's Avatar
paul16v
Monte 087
Yes they are 3.5k+vat at BARA,u do have to modify the beam and the groupa diff mount is no good,there is a specificalkly designed mount for a 9" diff,I think u have to drill a hole in the body aswell to fit this diff mount.Kevin Sahrp,breaking his escos in the parts section,he had the diff,now sold,he knows quite a lot about it.
CheeRS.Lee.
You dont have to modify the beam as long as you use a 2wd one the 9" diff fits staight in with no mods.
Old Apr 11, 2010 | 05:02 PM
1374lee's Avatar
1374lee
Ok Paul,good knowledge there.Sorry I was getting confussed as Kevin has an escos converted to rwd,different beam of course.
Thanks.Lee.
Old Apr 12, 2010 | 01:55 PM
Icekottarinn
Very interesting!!
Are you saying I could replace my 7,5" diff in my 2wd 3doors Sierra Cosworth with a 9" Ford diff without any mods, beam, cardan etc.?
I like it!
Have you any name of the car types I could buy the 9" diff from?
Old Apr 12, 2010 | 05:52 PM
grcossie's Avatar
grcossie
Here is ony guy, ho may have a 9" diff
http://www.escortrscosworth.com/foru...ad.php?t=12190
Old Apr 13, 2010 | 02:06 PM
R4N SS's Avatar
R4N SS
Default Supra mk.II diffs
Hi Mate,
Got any more info on what diffs these are and what models they came out of?
Also, where can you get the adapters cheap?
what sort of power/torque can they take?
Cheers in advance
Ran
Old Apr 13, 2010 | 02:07 PM
R4N SS's Avatar
R4N SS
doh - thought i had pm'd him
Old Apr 17, 2010 | 02:25 PM
markk's Avatar
markk
you could buy my 9" diff for 3.5k all if you want - unrun since rebuild !
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Sp3no
Sep 27, 2015 07:23 PM
