plug gaps
Old Apr 8, 2010 | 09:27 PM
botters's Avatar
botters
competant bodger
Default plug gaps
just took my cossie out for its first proper spin since i bought it a couple of months ago and when it comes on boost it backfires like foook! i remember the last owner said he replaced the plugs a few days before i bought it as it was choking up as all he ever did was move it in and out of the garage to clean it lol (0 miles covered last year and less than 300 miles in last 3 years) i havnt checked them myself yet but what gap should i set them too, its got stage 3 chip and running greens
cheeRS
Old Apr 8, 2010 | 09:28 PM
botters's Avatar
botters
competant bodger
oh i must add when not driving with foot down it drives great no misfires, hesitation or hunting
Old Apr 8, 2010 | 09:53 PM
KSA-Cossie's Avatar
KSA-Cossie
0.75mm
Old Apr 8, 2010 | 10:09 PM
botters's Avatar
botters
competant bodger
cheers ill give it a try tommorow hopefully all will be well till i get wasted spark!
Old Apr 8, 2010 | 10:23 PM
COLEYST200's Avatar
COLEYST200
you can all so go down to .6mm
Old Apr 8, 2010 | 10:32 PM
botters's Avatar
botters
competant bodger
ok mate ill start at .75 and go to .6 if no different then failing that ill get onto matt lewis for a heap of new sensors lol
Old Apr 8, 2010 | 10:54 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Standard ignition system (rotor arm/cap) and 803 dark greens - aim for around 0.65mm
Old Apr 8, 2010 | 10:58 PM
botters's Avatar
botters
competant bodger
cheers for the varied replies peeps i shall try all 3 different settings one at a time to see if any cure the fault, im glad plugs are a piece of piss to change on cossies lol!
Old Apr 9, 2010 | 08:14 AM
KSA-Cossie's Avatar
KSA-Cossie
Mine was ok at 0.75mm but go wasted spark m8 it's amazing.
Old Apr 9, 2010 | 09:58 AM
grcossie's Avatar
grcossie
Whit this, i run 1,1mm on 1,8bar boost whitout problem
http://www.malloryperformance.com/Pr...minselection=1
Old Apr 9, 2010 | 12:59 PM
You can also go down to 0.3mm if you wish, I find mine works best all round at 0.5mm, it may not be a spark problem as in the actual gap, coilpack is not the saviour many think it is, many high power yb's on std type coils, a megablaster 2 for example, more power than a coilpack, for less that 1/3 the price, and 10 minutes to change.
Old Apr 9, 2010 | 08:54 PM
botters's Avatar
botters
competant bodger
well i set them to .6 today and its now spot on boosts great keeps cutting out at junctions when coming to a stop but i dont suppose a 500 rpm tickover is helping that lol so ill give that a tweak tommorow and get my iscv sorted as well as thats unplugged at the mo think there is a problem with cts as valve appears to be working when tested off car and the plug on the car is getting power and a pulsed earth so i presume that is how it should be?
Old Apr 11, 2010 | 06:23 PM
ianbobo's Avatar
ianbobo
oohmamama
Excuse me for intervening m8s, Tabetha is the blaster 2 coil just a simple replacement for the 4x4 stock coil? No additional electrics involved? Can the standard ignition cables insulation withstand the extra electrical pressure?
thanks a lot.
Old Apr 12, 2010 | 08:18 AM
1cosworth's Avatar
1cosworth
big boost big gap
Old Apr 12, 2010 | 09:24 PM
botters's Avatar
botters
competant bodger
Originally Posted by 1cosworth
big boost big gap
sureley the big boost would blow the spark out on a big gap tho or am i missing something?
Old Apr 13, 2010 | 05:37 AM
grcossie's Avatar
grcossie
Thats use to happend yes, i have no problem after fitting Mallory hyfire6, grpA coil and 10mm plug wire. No i run 1.1mm, that makes better spark, use less fuel and runs better.
I have also used msd6a, ho is about the same as Mallory, but not digital.
Cheers Geir Rune
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
