Breather question...
Old Apr 8, 2010 | 09:02 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
Default Breather question...
Is it best to have as little pressure as poss in both the sump/block and Rocker area?? obviously in an ideal world with a healthy engine you wont see alot but on a worn engine you will. And where is best to return any oil from breathers.... above or below oil level?
Old Apr 8, 2010 | 10:17 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
Below oil level
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
kevin36
Sep 2, 2015 06:24 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
