The strongest & quietest RS turbo gearbox!!
Old Apr 8, 2010 | 06:22 PM
2ndGear's Avatar
2ndGear
Default The strongest & quietest RS turbo gearbox!!
After months of waiting the box is finally done - well nearly.I called to see how it was going on today and took some snaps. Im sick of ripping and blowing up boxes. Straight cut was just to noisy to use on the road so, shot peened aint all its cracked up to be.
See what you think!
MASSIVE BEARING
Old Apr 8, 2010 | 06:28 PM
cabrst's Avatar
cabrst
and what did all that set you back....
Old Apr 8, 2010 | 06:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah how much and why is it so good mate, is it forged, billet, etc..?
Old Apr 8, 2010 | 09:00 PM
Pete frst's Avatar
Pete frst
whats the score with that?................
Old Apr 8, 2010 | 09:37 PM
StephenC's Avatar
StephenC
..BS Motorsport..
this the 6 speeder???
Old Apr 8, 2010 | 09:46 PM
Neil@FastFord's Avatar
Neil@FastFord
Tell us more!
Old Apr 9, 2010 | 05:19 AM
JesseT's Avatar
JesseT
Looks like a Quaife gearset for the standard RST box.
Old Apr 9, 2010 | 07:01 AM
2ndGear's Avatar
2ndGear
Quaife dont do a semi helical kit for the rs turbo only striaght cut.
Custom built dogs bollocks box. Available in 5 and 6 speed!!!!
Old Apr 9, 2010 | 07:34 AM
Rick's Avatar
Rick
those bearings and gears look TINY compared to an MTX.
Old Apr 9, 2010 | 07:36 AM
Tim's Avatar
Tim
I never had problems with shot peened gears etc it was the layshafts pinion and crown wheel which were weak (always stripped them) ,these look no diff tbh carnt see it being lots better but i hope it does the job for you .
tim
Old Apr 9, 2010 | 07:48 AM
bigryrs's Avatar
bigryrs
RSHoleinator
Bc boxes aka before christ boxes are a waste of time! ive had a load of hassle with boxes especially second hand boxes and my advice to anyone who doesnt want to waste a load of money is go the mtx route as its a fit and forget jobby! like the old saying goes you cant polish a turd lol
Old Apr 9, 2010 | 08:04 AM
StephenC's Avatar
StephenC
..BS Motorsport..
Been talk of this for quite a while now hasnt there 2ndgear?
https://passionford.com/forum/restor...x-project.html
Has one been put through its paces???
Old Apr 9, 2010 | 09:32 AM
Pete frst's Avatar
Pete frst
will we know more about it before 60 pages roll by?...........
Old Apr 9, 2010 | 09:38 AM
StephenC's Avatar
StephenC
..BS Motorsport..
doubt it as I guess it will be classed as trading???
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah.... so what is good about it mate? Why is this one any stronger than a stock BC box?
Available in 6 speed, in a BC box??
Old Apr 9, 2010 | 09:47 AM
cossie j's Avatar
cossie j
+1 and if its any good your stop me from choping my genuine 50k series2 to fit a st170 box
Old Apr 9, 2010 | 01:39 PM
2ndGear's Avatar
2ndGear
the bearing center is bigger than mtx75, so these wont let me down. Bigger gears & stronger material allow the box to be stronger. Bigger teeth helical cut to make it acceptable on road. the 6 speed [prototype] was built using standard shafts and gears. Before i opted to get these beasts made.
I will add pictures later of the progress and details
Old Apr 9, 2010 | 02:26 PM
jammerrs's Avatar
jammerrs
do these have syncromesh or are they dog engagment?
Old Apr 9, 2010 | 02:48 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Ok sounds good, what material are they made from mate?
Old Apr 9, 2010 | 03:01 PM
jonny s2's Avatar
jonny s2
we would like to know more
Old Apr 9, 2010 | 03:02 PM
StephenC's Avatar
StephenC
..BS Motorsport..
If it is expensive a lot of people will still prefer it as it will save chopping the car about and messing with driveshafts etc. There must be a potentially huge (relative in car terms of course) market for these if they can take some hammer.
Old Apr 9, 2010 | 03:28 PM
gaz s1's Avatar
gaz s1
Agreed if it works i for one will be purchasing
Old Apr 9, 2010 | 03:34 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Well if it costs sub Ł1000 it would be worth it, cos a Stage 2+ CTS box (shot peened late BC box) it about Ł1800 with a Quaife ATB, if it's stronger than those then all good!
Old Apr 9, 2010 | 04:15 PM
2ndGear's Avatar
2ndGear
They use special custom forks (heavy duty), syncro rings (not dog engagement) shafts have extra oil ways for better lube, gears run on rollers etc etc etc and it has an ATB diff.
Ł2450
MAY SOUND ALOT BUT AFTER 3 BOXES IN MINE SO FAR ITS NOT
Old Apr 9, 2010 | 04:25 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It's just too much for most of us though fella, a CTS Stage 2+ will never be broken by 99% of us!
But I spose for the 300bhp+ boys it could be a good investment if you dont want to hack your car about and fit a MTX?
Whats your spec and BHP 2ndGear?
Old Apr 9, 2010 | 04:48 PM
jonny s2's Avatar
jonny s2
has it been tested to the max
Old Apr 9, 2010 | 05:20 PM
cossie j's Avatar
cossie j
Originally Posted by S1 JOHN S1
What did i say
You could have an MTX or ST170 6speed for that
If your chasing power (300HP) also you wont mind cutting the car
there's more to just cuting the car to fit a st170 box you'v got the speedo/ hydraulic clutch/ flywheel and for a bolt up bit of kit that dont sound to bad but id like to see it proven on a 400+bhp car first
Old Apr 9, 2010 | 05:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
400bhp+ RST!!! How many of those have you seen?? lol
Old Apr 9, 2010 | 06:05 PM
cossie j's Avatar
cossie j
i was on about zetec turbo's mind u i would like to see a cvh kick sumthing like that out
Old Apr 9, 2010 | 07:54 PM
DazC's Avatar
DazC
If I have box trouble, I'd buy it if I knew it was going to put up with the grief.
Old Apr 9, 2010 | 10:16 PM
rstdave's Avatar
rstdave
As above......if you were breaking stage 2+'s at Ł1800 a chuck (which a few have) then why would an extra Ł650 seem so ridiculous if it actually did the business?? It is indeed a LOT of wedge and i would also have to see it tested in some proper cars before shelling out but could be another option, certainly an easier one in terms of installation!
Old Apr 10, 2010 | 09:38 AM
DazC's Avatar
DazC
deffinitely. I'd buy it for ease of fitting and the fact it could take the abuse (once we know it can). No cutting up the inner wing then.
Old Apr 10, 2010 | 11:30 AM
StephenC's Avatar
StephenC
..BS Motorsport..
2nd gear, would straight cut be the same price? We really need to know how much power has been put through one of these.
Old Apr 10, 2010 | 11:44 AM
muz's Avatar
muz
Wye Valley Hardcore
Isn't the BC gearbox casing itself another inherant weakness though? Prone to flexing due to the lack of webbing causing bearing failure?
That said those gears do look good. I recently stripped my Quaife straight cut box down and the gears are so well made and strong looking. Difference to the standard gears I had lying about was night and day.
Old Apr 10, 2010 | 04:55 PM
jonny s2's Avatar
jonny s2
your correct muz
Old Apr 10, 2010 | 05:24 PM
gus's Avatar
gus
i would be very interested in seeing what this can handle
would be alot for me to change back to a bc box but i really dont wanna cut the wing
so would be worth the expense if it can handle the power / torque
Old Apr 12, 2010 | 04:59 PM
2ndGear's Avatar
2ndGear
i will put full spec up on thursday when i go over to see them
