ps3.cossie09
Old Apr 8, 2010 | 06:21 PM
cossie09's Avatar
cossie09
Default ps3.cossie09
hi,my ps3 give up last night 60g model.i have a new 120g one coming/will i lose all my game wins etc or do theygo on the new 120g one when i log on it.thanks
Old Apr 8, 2010 | 08:18 PM
cossie09's Avatar
cossie09
any body,is the 120g one any good.i miss mw2 big
Old Apr 8, 2010 | 08:21 PM
DanRSturbo's Avatar
DanRSturbo
Hello m8, What is wrong with the 60 gig one ? You will lose all your save game data so you will have to start your games again. Trophy information is the same I think, your Modern Warefare 2 info regarding rank and xp score is hosted on the servers I think.
jaiscossie's Avatar
jaiscossie
Not sure on ps3 but same thing happened on my 360 and lost everything was gutted
Old Apr 8, 2010 | 08:23 PM
Munch's Avatar
Munch
Mr. Sparkle!
Two separate Consoles mate, if you would of saved all your data from your 60GB, you coulda copied to your new system. You should still have your Trophies tho as that is saved to your PSN
Old Apr 8, 2010 | 08:26 PM
Harris.'s Avatar
Harris.
You will have to start the games you have from the start again.
As for online Ranks etc they are saved on the ps network so your ok there
I had 2x 60gb ps3s get the red light of death so i went and got the 120gb slim and so far its been good, you dont get the memory card slot though which is abit naff
Old Apr 8, 2010 | 08:36 PM
cossie09's Avatar
cossie09
cheers,it stopped playing games but still played dvds then i opened it to clean the laser,put back together now it wont play games or dvds.
Old Apr 8, 2010 | 08:38 PM
cossie09's Avatar
cossie09
can you put the 60g hard drive in the 120g one and have all the games scores and movies that thats on it.thanks
Old Apr 8, 2010 | 08:43 PM
DanRSturbo's Avatar
DanRSturbo
If the console powers up and you can access all the menu's then you can save your stuff, all you need is a usb hard drive or memory stick, plug it in and copy the info across and then do it on the new console. I've found data transfer rate via usb is slower on the slim consoles compared to the fat ones.
Old Apr 8, 2010 | 09:09 PM
cossie09's Avatar
cossie09
cheers dan,it powers up and will go to all the menu,s. the cover that keeps the wire strip for the cd drive has broke of the main board and the laser may need replaced.
Old Apr 10, 2010 | 06:07 PM
cossie09's Avatar
cossie09
hi,i got a new 60g ps3 today can i put the hard drive of the old 60g one in it so i have all my games that are saved etc
