secs monitor wiring
Module Connector 1 Pin 8 (Black) > ECU Pin 1: Ground
Module Connector 1 Pin 7 (Red) > ECU Pin 20: 12V Possitive Supply
Module Connector 1 Pin 5 (Brown) > ECU Pin 25: Ignition Signal For RPM Reading
Module Connector 1 Pin 4 (Green) > ECU Pin 17: TPS
Module Connector 1 Pin 3 (Blue) > ECU Pin 29: Engine Coolant Temperature Sensor
Module Connector 1 Pin 2 (Yellow) > ECU Pin 31: Air Charge Temperature Sensor
Module Connector 1 Pin 1 (White) > ECU Pin 15: MAP Sensor
: king:
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
