Changing coilpack Focus for an Escort one?
The coilpack on my Focus 2.0 ('02) has started to fail. I replace it for an escort zetec item which has the same connector and it runs sweet now. Just needed the leads too to get it installed. It wont fit at the focus bracket so I'll think I need the escort bracket as well.
But my question is can this swap do any damage to the Focus PCM (ECU)?
Thanks Tabetha, that's what I thought too
. What I have heard is that when using bad sparkplugs or HT leads the high voltage would damage the inside of the Focus coilpack. Something that I have never heard about the old Zetec ones.
So now I made up the Focus bracket so that it can have the old zetec coilpack. Bloody hard to do...
The best thing you can do is find yourself a old zetec bracket. At this both old and new coilpacks will fit!
. What I have heard is that when using bad sparkplugs or HT leads the high voltage would damage the inside of the Focus coilpack. Something that I have never heard about the old Zetec ones.So now I made up the Focus bracket so that it can have the old zetec coilpack. Bloody hard to do...
