escos running very rich??
Old Apr 6, 2010 | 08:06 PM
cossiedrift's Avatar
cossiedrift
Default escos running very rich??
Just fitted msd 380+ chip and my emmisions readings are 11%+ co 4000+ ppm hc its that bad its smoking and hurts your eyes lol Not saying it's the chip causing it tho.
Any idea's what could be causing it? i tried ringing them earlier for advise but they must have been busy. Going to try a new lambda sensor tommorrow if i can get one. When i unplugged the lambda it went down to 5+% co. Is this normal??
Thanks Danny
Old Apr 6, 2010 | 08:12 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
I had a saff that i put my rebuilt engine in that overfueled so bad my eyes were streaming.
Just put a Swedish plenum on it too so it needed a serious setup.
Old Apr 6, 2010 | 08:20 PM
James @ M Developments.'s Avatar
sounds shocking!
test map sensor, ect,act, and lambda to start with, make sure you have no air leaks and check the fuel pressure is standard, i had one in last week on a 5 bar fuel reg
Old Apr 6, 2010 | 08:30 PM
and if you have removed a pectel board it may need an adaptation reset if its P8
Old Apr 6, 2010 | 08:34 PM
cossiedrift
James, map sensor is also new from yourselves and it has standard fpr no air leaks but is p8 so i suppose it may need resetting.
All other sensors are new bar phase and tps. and the lambda which i'm going to try.
dombanks
Sep 21, 2015 08:38 PM
Eigdoog
Sep 13, 2015 05:46 AM
gcfcos
Sep 11, 2015 06:03 PM
Mickeystewart
Sep 9, 2015 04:04 PM
