Changing coilpack Focus for an Escort one?
Old Apr 6, 2010 | 07:06 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Default Changing coilpack Focus for an Escort one?
The coilpack on my Focus 2.0 ('02) has started to fail. I replace it for an escort zetec item which has the same connector and it runs sweet now. Just needed the leads too to get it installed. It wont fit at the focus bracket so I'll think I need the escort bracket as well.
But my question is can this swap do any damage to the Focus PCM (ECU)?
Old Apr 7, 2010 | 07:58 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Bump
Old Apr 7, 2010 | 08:52 AM
RichieST's Avatar
RichieST
To be honest I wouldn't risk it. Although its probably the same inside just with different fittings so it should be alright, but I would rather replace with the proper item to be on the safe side!
What normally causes the coil packs to fail is the spark plug gaps are too large, so the coil pack is being stressed firing the spark across the plug which causes premature failiure. Could be worth sticking in a new set of plugs or regapping them too!
Old Apr 7, 2010 | 08:55 AM
Stevie-Boy's Avatar
Stevie-Boy
Gettin There
Easiest thing to do mate is check the Ford part numbers and if they are the same then all is good but if it lists a different one for Escort and Focus then i would steer clear.
Vincereese
Jun 1, 2023 09:14 AM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
