Brake fluid DOT 4 or DOT 5.1
Old Apr 5, 2010 | 07:26 PM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Default Brake fluid DOT 4 or DOT 5.1
Help me please - need advice on best brake fluid or whether there isnt much to worry about.
Got 4x4 cossie front calipers with 2wd discs and the standard drums on rear
What is my best option?
Old Apr 6, 2010 | 09:19 AM
bezo's Avatar
bezo
powered by K26
i run the same set up as you. DOT4 will be fine
Old Apr 9, 2010 | 03:37 PM
daveandhelenturbo's Avatar
daveandhelenturbo
I have 5.1 in mine on the same set up.
Dave
Old Apr 9, 2010 | 03:50 PM
jammerrs's Avatar
jammerrs
5.1 will be better, but unless you drive it like you stole it from the moment you start it till you stop dot 4 would probably be ok
id still go for 5.1 though
Old Apr 10, 2010 | 11:50 AM
muz's Avatar
muz
Wye Valley Hardcore
DOT 5.1. Make sure it's 5.1 and not 5 though
muzzman1
Sep 30, 2015 08:59 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
