Can 380+BHP really be acheived on a standard 2wd cosworth?
Old Apr 5, 2010 | 06:31 PM
Cossie_ray's Avatar
Cossie_ray
Default Can 380+BHP really be acheived on a standard 2wd cosworth?
Hi all,
I was reading on MSD website that you can have 380BHP + on a standard engine running
there chip, 3bar map sensor, -34 actuator, T34-55 and siemens 55s.
Can this really be achieved on a standard engine with with standard pistons, standard compression and standard cam.
I thought the standard compression on a cosworth would be wrong to run this power.
Cossie Ray
Old Apr 5, 2010 | 06:35 PM
Captain500rs's Avatar
Captain500rs
Yeah no problems
Old Apr 5, 2010 | 06:48 PM
gibbo1979's Avatar
gibbo1979
They are the "boyz" and yes it can. Go for it mate
Old Apr 5, 2010 | 06:51 PM
bad boy rs's Avatar
bad boy rs
me mate had 450 with standard bottom end
Old Apr 5, 2010 | 07:10 PM
knightsy's Avatar
knightsy
Originally Posted by Cossie_ray
Hi all,
Cossie Ray
i know its not 2wd, but i have just fitted this conversion to my BT escos, it was stage 1 before this, it is now fitted and im having it checked on a rolling road with a power run on thursday so i will post up the results. i have give it some stick in first and second and it goes like . fuel consumption is way better normal driving aswell.
Old Apr 5, 2010 | 07:16 PM
Yes you can also achieve this easily with anyones stuff, on a T34.48, as the nice chap at CR turbos used to have on his very own 2wd cossie, and more, greys will also achieve this perfectly IF mapped correctly with ace emissions and economy.
Old Apr 5, 2010 | 07:21 PM
knightsy's Avatar
knightsy
has this always been the case , what i mean is, is this a fairly recent thing, i had my last cossie 8 years ago and back then to get 380-400 bhp you would need low compression, flowed head etc etc, is this just because of the advances in mapping.
Old Apr 5, 2010 | 08:01 PM
the saint's Avatar
the saint
i had an msd chip in my sapph with T4 and greys ect on a standard engine and it ran a treat and went like fuck too just wish i had a better headgasket lol
Old Apr 5, 2010 | 09:16 PM
bad boy rs's Avatar
bad boy rs
380 on a t34.48 & greys ?
Old Apr 5, 2010 | 09:28 PM
cozzy940's Avatar
cozzy940
yes mate 3 bar t34 grp a headgasket greys chip, done
Old Apr 5, 2010 | 09:32 PM
KSA-Cossie's Avatar
KSA-Cossie
Had this conversion on my saph and it's awesome but ive gone for more power now lol.
Old Apr 6, 2010 | 01:51 PM
Captain500rs
Greedy fooker...Always the case mate, you always want more lol , i had a bit fuck about with a scooby on sunday night and was like fuck it i want it faster
Old Apr 6, 2010 | 02:00 PM
Staffi's Avatar
Staffi
What have you got now then Kev?? didn't realise you'd moved up in power bud, thought you had plenty for that 4x4 box...
Old Apr 6, 2010 | 02:03 PM
KSA-Cossie's Avatar
KSA-Cossie
Funky new SCS engine pete.
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Hi all,
Cossie Ray
Yep. Runs really well and goes like stink! For ultimate reliability it's recommended to do a head gasket and oil breather upgrade as well.
Old Apr 6, 2010 | 02:13 PM
Staffi's Avatar
Staffi
You kept that quiet Nephew.... very nice too.
Ray,
Sorry for hi-jacking,
To answer your qustion, yes mate it's a doddle to do and makes a great road car too..
Old Apr 6, 2010 | 02:33 PM
Cossie_ray's Avatar
Cossie_ray
Cheers guys.
Much appreciated..
Old Apr 7, 2010 | 01:02 PM
Certainly don't need to lower CR's like most do, even for some 330-350 tunes, better ecu control, or rather better injector control has played a massive part in tuning, esp over the clockwork L1/6 etc.
I'm on greys with 0.97% CO with 137PPM, with just under 190,000 miles on the bottom end, but I do flush every oil change, I'm only running 17/18 psi at the mo due to wear, but yes 380 easy on a .48 t34.
Old Apr 7, 2010 | 01:14 PM
scarnny's Avatar
scarnny
What size exhaust would you need for that sort of power would 2.5 be big enough or would you need 3inc?
Old Apr 7, 2010 | 01:20 PM
Staffi's Avatar
Staffi
Scarnny, 3" preferably bud, that's not to say a 2.5" wouldn't....i sound like i'm on the fence there don't i?? but you get my meaning..
Old Apr 7, 2010 | 01:44 PM
scarnny's Avatar
scarnny
So what your saying is 380 can be done with 2.5. Only asking because I'm ltd for space and don't think I've got room for a 3inc pipe.
Old Apr 7, 2010 | 04:36 PM
bad boy rs's Avatar
bad boy rs
realy didnt think 380 was possible on a t34.48, its what im running on my stock engine with greys and all the other goodies, peak 30 and holding 28 all the way through, shoukld get it on the rollers realy to see what shes making, may change to .55 though as it hasnt quite got the guts at top of revs
Old Apr 7, 2010 | 05:32 PM
Staffi's Avatar
Staffi
My old 3dr made 363 bhp with similar torque on T34.48 Greys, that peaked @ 32 psi and dropped off as they do, was a great road car that AND if i ever do mod the current 3dr it'll be same again...
Old Apr 7, 2010 | 05:36 PM
bad boy rs's Avatar
bad boy rs
is a perfect setup but lags top end punch on the small housing
Old Apr 7, 2010 | 06:22 PM
Staffi's Avatar
Staffi
It did over 150 regularly so it never botherd me.... and whilst BIG bhp cars are/were struggling for grip, you're gone..
Just have a browse through some old Performance Ford mags when they did all the tests. 0-60 0-100 etc, T34 cars aint bad.. neither were Tiffs & Popeyes Gunship T3 cars..
Old Apr 7, 2010 | 06:28 PM
martysmartie's Avatar
martysmartie
Engine internals are fine, I think it used to be the done thing everyone lowered CRS for some reason, loads of boost and away you went don't know why as it makes for a horrible drive. With .55 you would see an easy 380 but think that would be the max for .48
Martin
Old Apr 7, 2010 | 06:41 PM
bad boy rs's Avatar
bad boy rs
[quote=Pete 3dr;4837758]It did over 150 regularly so it never botherd me....
so did mine lastnight
Old Apr 7, 2010 | 06:58 PM
get it done fella.
Old Apr 7, 2010 | 07:06 PM
joe s's Avatar
joe s
What would be the max bhp for mine out of curiousity?? T35.63, 500 cooler, greys, L6 with stage 3 chip?
Old Apr 7, 2010 | 08:30 PM
avinit1rs's Avatar
avinit1rs
AV IT!!!
Where do you guys recommend getting a t34 from? and what would i expect to pay?
Old Apr 7, 2010 | 09:14 PM
Staffi's Avatar
Staffi
Hard to say a MAX Joe, but i'd go for 370-390 give or take 10bhp eitherway..
Turbo Technics/ CR Turbos/ AET Turbos...
Old Apr 7, 2010 | 09:18 PM
Cossie_ray's Avatar
Cossie_ray
Ebay mate or on the cosworth parts for sale section on this site. They normally go about Ł250.00 used. .55 housings are quite rear so turbo will probably come the .48 housing.
Old Apr 7, 2010 | 09:26 PM
Cossie_ray's Avatar
Cossie_ray
One on the bay. You will have to check the condition of it, if it is used.
http://cgi.ebay.co.uk/Cosworth-Turbo...item439e812b3d
Old Apr 7, 2010 | 10:18 PM
KSA-Cossie's Avatar
KSA-Cossie
What boost,spec of engine etc ?
Old Apr 7, 2010 | 10:19 PM
KSA-Cossie's Avatar
KSA-Cossie
Vince at CR turbos
Old Apr 8, 2010 | 07:04 AM
WongRS's Avatar
WongRS
Stop making your car better than mine! lol
Old Apr 8, 2010 | 09:29 AM
KSA-Cossie's Avatar
KSA-Cossie
Lol , quaiffe diffs to be fitted yet dan.
Old Apr 8, 2010 | 05:02 PM
Staffi's Avatar
Staffi
Money bags these Scottish fookers.............
Old Apr 8, 2010 | 05:08 PM
WongRS's Avatar
WongRS
haha, must be alot of good jobs up there!
Old Apr 9, 2010 | 05:52 AM
joe s's Avatar
joe s
Thanks Pete, thats what I was hoping for. Think I'll get it set up for that then lock it down to 350bhp.
