cossie header tank
Old Apr 4, 2010 | 08:10 PM
m7ck's Avatar
m7ck
Default cossie header tank
i have a 2wd header tank and it needs replacing
i am right that 2wd plastic are not available anymore ?
are 2wd and 4wd tanks all same size height turret shape etc for all years ?
i know i will have to buy new pipe work unless anyone has made some kind of reducer ? and i will also need to cut this new pipe as i have a swirl pot so need to use a t-piece on that
thanks
Old Apr 4, 2010 | 08:15 PM
martysmartie's Avatar
martysmartie
Correct 2WD header tank is no longer avaliable from Ford, and indeed hard to find elsewhere. 4x4 I think is for £30. As you say the outlets are different but can easily adapt if you are good at that sort of thing, same dimentions though. Shoulden't have to cut pipes.
Martin
Old Apr 5, 2010 | 07:42 PM
Roose do a 2wd turbo to 4wd tank pipe, around £32 delivered so no pipe cutting involved, direct replacement a 4wd tank for 2wd tank.
Old Apr 5, 2010 | 07:44 PM
m7ck's Avatar
m7ck
thanks for replies guys
Nov 1, 2015 06:53 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
mpilk
Sep 27, 2015 09:21 AM
