newbie
Old Apr 4, 2010 | 08:06 PM
first_cosworth's Avatar
first_cosworth
Default newbie
hi folks
as you can probaly tell i'm a newbie!
i have just bought my first cosworth,its a 1990 magenta 4x4.
its been loved in the past but now needs a little attention!
it has a running problem,if you try and start it you need to give it a little touch on the throttle pedal to catch.
it also has a light missfire up to 4.5k then it wont rev any further,tried a set of 071 ford plugs (new ungapped) and no difference.
can anybody help?
car seems to be stage 2,filter,exhaust,actuator and green injectors.
sorry for the big first post but hopefully this is a friendly place!
Old Apr 4, 2010 | 08:16 PM
24vcossiemat's Avatar
24vcossiemat
no more Granada's for me
hello mate, welcome to passionford.. you should get all the help you need on here, right from radio codes to full resto's.. unfortunately I can't help with the problem as i'm not clued up on turbo Yb's but most of them on here are.. I found when i joined this site that people didn't have a lot of contact with me at first but after a while people get to know you.. good luck with the cossie mate
Old Apr 4, 2010 | 08:27 PM
opposite lock's Avatar
opposite lock
Hi there welcome to PF theres an abudance of info on here your in good hands , i dont know what may cause your running issues but your best to get the car seen by a proffesional for a setup as theres lots of things that can go wrong. dont get put off by it they are superb cars and deserve lots of attention especially if you dont know its history
Old Apr 4, 2010 | 08:30 PM
martysmartie's Avatar
martysmartie
Hello and welcome.
When the car is started with throttle assistance does it stop if shut if so most likely ISCV, as your problem sounds fuel related I won't touch on the ISCV as the below may sort both.
Besides the plugs which you have changed and to one of the best ones possible as well (071's), what gap have you set? the rest of the ignition system needs to be in perfect order on these as it's not great. I.E Rotor arm, ignition leads. Also good idea to change fuel filter, this is often overlooked. Other thing it could be is CTS but do the above simple checks first. Do you get black smoke out?
Most important thing of all is to make sure fans work, should be rewired ideally if not already done, same applies for fuel pump.
Martin
Old Apr 4, 2010 | 08:33 PM
first_cosworth
aye,had read about the rewiring jobs to the pump and fans, the plug gap was not checked sorry,rotor arm and dizzy cap on its way,
yes do get some black reek and old plugs were black from being rich.
sorry but what is the cts?
cheers for the replies so far
Old Apr 4, 2010 | 08:49 PM
martysmartie
CTS (Coolant temperature sensor) at back of head under plenum, is tricky to get at it's a thermister that provides the ECU with info on coolant temperature from 0 degrees to boiling these do go out of calibration after a while and hence give false readings leading to rich mixture.
Forgot to say in last post but a common one, check the MAP sensor hose, under header tank beneath a fender this connects to the plenum. These can simply come off (It's a good idea to cable tie for this reason) when they do they run very rich, if not this they also split!
Same applied to fuel pressure regulator if this comes off though you go to other extreme of leaniness and could lose engine so again good to make sure it's in good condition/connected.
Martin
Old Apr 4, 2010 | 09:03 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
Welcome to pf!
Old Apr 4, 2010 | 09:04 PM
first_cosworth
hi martin
cts = doh simple!
will check the connections you mean when i next see the car in daylight!
this is the offending article
also this is the spare,what is it? its 17 inch btw.
Old Apr 4, 2010 | 09:20 PM
AndyPen's Avatar
AndyPen
Best colour - well someone had to say
Welcome mate - all the advice above sounds good to me.
Andy
Old Apr 4, 2010 | 09:42 PM
martysmartie
Looks good condition, I like the standard lattice wheels you have, someone had different alloys before and probably put originals back on when they sold, looks like a 4 spoke RS wheel more commonly there 7.
Martin
Old Apr 5, 2010 | 08:06 AM
first_cosworth
aye but its a 5 spoke!
Old Apr 5, 2010 | 08:21 PM
cossiejsy's Avatar
cossiejsy
hello and welcome to pf
nice looking cossie
Old Apr 5, 2010 | 08:25 PM
first_cosworth
cheers guys,would this be the appropriate section to ask abut the radio code for the standard stereo?
Old Apr 6, 2010 | 06:05 PM
bazza1975's Avatar
bazza1975
Alrite there, welcome, nice motor by the ways!
Old Apr 6, 2010 | 06:10 PM
first_cosworth
hullo bazza long time no see!
Old Apr 6, 2010 | 08:29 PM
martysmartie
Hey it was late at night and I was tired, as you say 5 spoke don't know why I imagined 4, can't blame alcohol either! I can't get the codes for the older head units only for modern ones but sure someone can.
Martin
Old Apr 6, 2010 | 08:33 PM
first_cosworth
lol @ martin!
do you know what those wheels are?
no worries about the codes,but if anybody could point me in the right direction i would be very thankfull
Old Apr 6, 2010 | 09:23 PM
martysmartie
I would say RS 5 spoke but can't be sure. People on here can get the codes same as me but probably only modern M codes. Someone probably can though.
Martin
Old Apr 7, 2010 | 05:31 PM
bazza1975's Avatar
bazza1975
Very long time no see, should be visiting overseas again this summer for a few stella's and some bucky.
Old Apr 7, 2010 | 05:35 PM
bazza1975's Avatar
bazza1975
Those 5 spokes not an aftermarket wheel available from the dealer back then.. 15inch anyways, maybe 17 was meant for the granada..
Old Apr 7, 2010 | 06:34 PM
first_cosworth
remember i will be stopping of at yours on the way to the ring!
Old Apr 7, 2010 | 06:54 PM
hello and welcome. Have you got it sorted then.
Old Apr 7, 2010 | 06:56 PM
first_cosworth
no goes in tommorow,but still need help with the radio code,if anybody could that would be great!
Old Apr 7, 2010 | 07:14 PM
The Crocodile Hunter's Avatar
you can get radio codes online for a few quid, got one for a pug 106 radio not too long ago. Cant remember where from just did a google search
Old Apr 8, 2010 | 06:25 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
hello and welcome to passionford ship mate
Old Apr 8, 2010 | 07:21 PM
first_cosworth
thanks folks
so in today, sensors ,leads,dizzy etc are showing up fine,runs better when the map sensor is disconnected and the injector duration goes mad when its reconnected., so he is thinking either map sensor or the chip itself.
on my first decent drive of it today,it ticks over at 2 k when warm,and doesn't seem to be boosting much,no boost guage (yet) so dont know what its doing.
but its deffo over fuelling.
any thoughts?
Rammer46
Sep 18, 2015 08:31 AM
Bezzy41
Aug 3, 2015 10:31 AM
markymark7890
Aug 23, 2005 09:30 PM
craig b
Fiesta RS1800/RS Turbo
Aug 6, 2005 03:51 PM
Ford Focus RS
Dec 31, 2003 07:02 AM
